Quick wiring question
Old Jan 7, 2013 | 10:07 PM
BluBob's Avatar
BluBob
Default Quick wiring question
I have my tank off and replaced my triple trees. I have reconnected the turn signals on both side and the left and right bundles that come through the trees. Now I have the connectors that go to the dash and tank sorted out, but can't identify this one here:
Its a four wire with flat blades inside the connector. The wires are solid red, white, yellow, and black.
I just want to know if I need to fish for its mate up in the neck or if it is somewhere on the tank or dash that I missed. Thanks for any help.
Old Jan 7, 2013 | 10:39 PM
arkstreetbob's Avatar
arkstreetbob
If that wire is orange/white and not red could be head light.
Old Jan 7, 2013 | 11:12 PM
HDCustomFabrication's Avatar
HDCustomFabrication
OR/Wh is usually accessory power. White, Yellow and Black usually go to the headlight.
Check your fuel pump/gauge, other than those not sure what that would go to up front.
Old Jan 7, 2013 | 11:22 PM
paullavery's Avatar
paullavery
Looks like the connector for the headlight to me !
Old Jan 8, 2013 | 06:02 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
100% sure it's the connector for the head light harness
Old Jan 8, 2013 | 08:10 AM
tomt's Avatar
tomt
Rule #1. Always tag cables before pulling them apart.
Look for a plug that has the same dimensions and same number of sockets and see if they fit together.
Better yet. Put the cable down and take a photo of the whole cable. From were it starts and finishes. And a photo of what plugs you have left over that's not connected. Post them and let us have a look.
Old Jan 8, 2013 | 08:13 AM
DesertDyna's Avatar
DesertDyna
Easier: turn the bike on and see what doesnt work....
Old Jan 8, 2013 | 08:21 AM
HDCustomFabrication
Instead of tagging and photographing, which is not a bad idea... Get the wiring diagrams, if you don't have a service manual, which includes them, try this link that Rene was good enough to post for everyone.
https://www.hdforums.com/forum/dyna-...-part-1-a.html
Old Jan 8, 2013 | 08:42 AM
FXD2003Rider
That's where I found the answer to OP's question, Rich!
Old Jan 8, 2013 | 08:44 AM
HDCustomFabrication
I am just surprised I beat you to it... I picked it out of the old dead brain cells...
