Dead Battery ??? Jump Start ??
Old Jan 9, 2013 | 06:08 PM
Dozer40's Avatar
Dozer40
I hear ya...they probably had their shop boy check the voltage only. You think they'd be happy to get a little deeper in your wallet.
Old Jan 9, 2013 | 06:40 PM
PigInaBlanket's Avatar
PigInaBlanket
If you need a battery and have an Advance Auto nearby you can get an ETX20L battery from them for $69.99 using code TRT41.
It has 310CCA (stock is 270), 17.5 amp hours (I believe stock is 19 but I could be wrong) and 1 year warranty.
It is also made by East Penn.
I bought one last February and it has been fine. I'd buy one again when the time comes.
Here is the link to it
http://shop.advanceautoparts.com/web...IdSearch=33736
Old Jan 10, 2013 | 07:37 AM
annapolisfatbob's Avatar
annapolisfatbob
Thanks for the promo code and everything...picking one up today! You are the Man pig!
Old Jan 10, 2013 | 07:55 AM
Muppet Master's Avatar
Muppet Master
Have you tried clutch starting it? Third gear usually works best for these larger bikes.
Old Jan 10, 2013 | 08:04 AM
rh8234's Avatar
rh8234
I don't know what HD dealers use for a battery tester, but I do know it ain't reliable. I took my one year old battery form my Ultra in to be tested. They gave me a real little print out that says "Bad Cell - Replace,Voltage 10.84, zero cca, amp hours 00.00". I bought a and installed a new battery. For fun, I stuck the old one on a tender for three days, and the battery is working just fine in my lawn tractor now.
Old Jan 10, 2013 | 10:13 AM
JRK5892's Avatar
JRK5892
Pig great tip and link!
Old Jan 10, 2013 | 12:26 PM
02fx4dude's Avatar
02fx4dude
A battery tester in the wrong hands is useless, and testing a partially charged battery will give the exact results they gave you.
A real tester will charge the battery full, then partially discharge it, and repeat several times. Batteries plus used to have computerized testers that you would leave the battery overnight and it would do exactly that, not sure if they still do.
Old Jan 10, 2013 | 01:10 PM
rh8234's Avatar
rh8234
That's exactly my point. Do not trust the dude at the dealership to give you any accurate indication if the battery is good or bad. They can test a battery that is perfectly good and determine that it is hopelessly worn out. I suspect they could also tell you your battery is fine when it is marginal.
Old Jan 10, 2013 | 03:50 PM
max3099's Avatar
max3099
I was just looking for this link in a past thread. Thanks!
Old Jan 10, 2013 | 04:51 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Originally Posted by antman27
What pisses me off about that is ... I was at Harley 2 months ago ..I said hey the bike is an 07 lets change the bat while you have it . They said they put the tester on it and it was FINE no need to spend the $$ on a new one yet
That's the bad thing about only having electric start on our bikes. Batteries will do that though, they may read strong one day and the next dead. It happened on my wifes car.
