Question about 21" Front Wheel
Old Jan 19, 2013 | 04:01 PM
One Vision's Avatar
One Vision
Default Question about 21" Front Wheel
Hey gang,
I just had my bike picked up today for the winter mods to begin:
-Switch out rear spoked wheel and replace with a solid chromed Deuce wheel
-Replace Burly Slammers with Progressive 11" rear shocks
-Replace front lowers with chromed lowers
-Replace tires
-replace rear tail light with low profile smoked style
My bike is a 2009 Super Glide Custom.
Here is the question: Going from a 19" to a 21" front wheel will the stock fender accomodate the new size? We will see if I need new Fork Tubes etc. But we weren't sure about the fender.
Thanks all!
OV
Old Jan 19, 2013 | 05:00 PM
tcabello's Avatar
tcabello
On the '09 Bob the front fender looks great with a 21" tire with no mods...not 100% sure if your front is identical to mine though.
Old Jan 19, 2013 | 07:08 PM
Hogpro's Avatar
Hogpro
Former Sponsor
It will bolt right on as long as it is a 21x2.15. It can get a bit tight with a 21x3.25. The brackets for the fender will be extremely close to the tire if not touching with the wider rim and tire.
Old Jan 19, 2013 | 08:55 PM
macnab_sf's Avatar
macnab_sf
I have a street bob, and the 21x3.5 rim fits under the fender wearing a Metzeler 120-70-21 tire. Not sure if we have the same fender, but pretty sure it will fit for you too.
Old Jan 19, 2013 | 10:03 PM
Reindeer's Avatar
Reindeer
I'm running a 90/90-21 on my '09 FXDC and it fit fine with no mods to the fender.
Are you relacing a new rim on your stock hub?
Old Jan 19, 2013 | 10:45 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The street bob's are with the 49mm front ends are different than the 05 and earlier Dyna's with the 39mm front ends.
Old Jan 19, 2013 | 11:58 PM
big ron's Avatar
big ron
@macnab_sf - How did the switch effect the handling. We do alot of mountain rides and I am not looking to reduce the handling to improve the looks.
Old Jan 20, 2013 | 12:06 AM
Joboo1966's Avatar
Joboo1966
Won't be an issue.
Old Jan 20, 2013 | 01:13 AM
macnab_sf's Avatar
macnab_sf
My handling improved. My 21" rim is aluminum, where the stock 19" rim was steel.
Old Jan 20, 2013 | 01:15 AM
macnab_sf's Avatar
macnab_sf
Agreed, just saying what worked for me. I believe the OP has an '09.
