Verify torques for me please
Old Jan 23, 2013 | 06:50 PM
Stangheel's Avatar
Stangheel
Default Verify torques for me please
I am installing big radius 2 into 2 on my wide glide... Instructions don't give specified torques and I'm unable to buy a service manual right now. I've researched on here as much as I can, so here's what I have if someone could verify.
flange nuts- 60-80 in-lbs. (i have the technique as well)
O2 sensors - 29-34 ft-lbs ( this seems to be a lot compared to nuts?)
allen head screw in xmsn housing ???
bolts holding bracket to xmsn housing ???
Also, if anyone notices there's something missing it will be greatly appreciated as well.
Thanks guys!
Old Jan 23, 2013 | 07:19 PM
izzyryder's Avatar
izzyryder
I found this:
http://www.google.com/url?sa=t&rct=j...41248874,d.dmQ
I've always tightened the flange nuts hand tight, never torqued them. I hand tight, ride for a while, then retighten as the gaskets compress.
On the O2 sensors, make sure you apply anti-seize on the threads. Again, i've never torqued them, just snug them. They won't budge.
If I remember right the bolt in the trans housing is 10 to 18 ft lbs.
Old Jan 23, 2013 | 07:40 PM
Stangheel's Avatar
Stangheel
thanks for the info Izzy. Those instructions look like an older version of what came with my pipes. I usually go with german torque and anti-sieze as well, but thought I might try to do the recommended since this is a new bike. I may just see how what I've found goes and feels and go with just tightening everything down to my likening...
Old Jan 23, 2013 | 07:49 PM
RJHD's Avatar
RJHD
Tried to attach a pdf of the Torque values, but the file is too big. (Not sure why, it's a .pdf?) If you PM me your email, I'll shoot it off to you.
Old Jan 23, 2013 | 07:52 PM
Stangheel's Avatar
Stangheel
PM sent, tnx
Lambda
Engine Mechanical Topics
11
Apr 22, 2016 07:44 AM
iDodgimus
Apr 8, 2012 11:51 AM
indyjeff
Sep 30, 2007 09:52 PM
Demkay
Jun 26, 2007 10:42 PM
Rhubarb
Exhaust System Topics
Sep 28, 2006 04:31 PM
