View Poll Results: HID or LED
LED
14
66.67%
HID
33.33%
Voters: 21. You may not vote on this poll
HID vs. LED ????
Old Jan 26, 2013 | 07:55 AM
Billyram's Avatar
Billyram
I decided I wanted to try and get more light out of my 5-3/4" head light so I tried differant bulbs with little differance that sometimes left me in the dark. Next I went with a 35w hi/lo HID with more light but not very focused. I wasn't impressed so I ended up with Harleys LED with not as much light but more light where I can use it. The HID flooded light every where but wouldn't reach down the road like the projection beam LED. You just can't seem to be able to get enough light out of a single 5-3/4" light and the LED is only marginaly better than some bulbs. The 7" head lights are a world better and the dual 5-3/4" Road Glide really light up the road.
Billy
Old Jan 26, 2013 | 08:32 AM
pexcomike's Avatar
pexcomike
I went with the Phase 7 LED by Truklite..fit my Fatboy perfectly, although it did protrude from stock housing...French trim ring fixed that..honestly, still have mixed emotions about the LED...ANY LED headlight...although much ,much brighter than stock,visibility from an angle is less...it's a tradeoff I guess
Old Jan 26, 2013 | 02:44 PM
Jondalar's Avatar
Jondalar
I went with the L.E.D. in my '13 Superglide Custom simply because it's what they sell at my local dealership. I like them and I support them.
Old Jan 27, 2013 | 09:26 PM
0pini0nated's Avatar
0pini0nated
Default Experience with H-D 5-3/4" LED headlight -
On my 2005 FXST Softtail Standard, I originally had a minor vibration problem with my Harley-Davidson OEM 5-3/4" headlight. It wasn't too bad with the H4 that came with it ~ it was a quirk, and at night, the other cars around me knew it was a motorcycle by the bobbing-up-and-down as I passed by.
But my new LED brilliant white light put this "quirk" in a new perspective!! 1) Reflecting road signs are *terrible* at dusk and at night. Any sign with reflecting material (like PennDOT signage) looked like a large strobe-affect sign! It was very distracting. 2) The LED headlight is very sensitive to adjustments. The beam cut-off, at the top and bottom, was distinct. Because of the beam cut-off at the top, when I turned, I had to hit the HI beam to illuminate the turn. 3) A few other drivers in front of me pulled aside so I could pass - apparently they thought I was blinking at them (or they just didn't like the blinking strobe-effect in their rear view mirrors.)
I finally minimized the strobe problem by jamming some 5/8" heater hose between the LED unit and the inside of my headlight bucket.
On my wife's V-Star 1100 Classic, I bought / installed a PIAA H4 Xtreme White Plus Anti-Vibration Headlight Bulb. It was a better solution ($40 for a bulb versus $400 for the LED headlight P/N 73273-11A) and it *really* lit up the road at night.
Last edited by 0pini0nated; Jan 28, 2013 at 10:13 AM. Reason: attached image still isn't visible
BlackPearl#1
May 9, 2016 04:08 PM
201048
Aug 1, 2013 08:09 PM
3rdgear
May 18, 2013 12:13 PM
Blk and Chrome
Feb 19, 2011 05:22 PM
CK3248
Electrical/Lighting/Alarm
Jan 17, 2011 11:54 AM
