handlebars
Old Feb 9, 2007 | 06:25 PM
Trotter's Avatar
Trotter
Default RE: handlebars
ORIGINAL: glideridemike
is that a HD #?
Yea 70239-07 Handlebar Switch Control Kit 60" of wire
Old Feb 9, 2007 | 07:14 PM
Trotter's Avatar
Trotter
ORIGINAL: thebestofindica
Yeah, its a hd number. Its the controls and wire, but you have to crimp ends on to the wire. Not a big deal. What bars are you going to? I'm putting apes on the bob and bought a novello kit from JP. Around $50. A little more work involved with novello kit though. You have to pull wires out of connector, put in wire kit and then put connector back on. Shouldn't be a huge deal though.
Yeah, you slide tank back (take of quick connect fuel line on left side of bike), then you pull grommet out of frame at front of bike, for additional wire you can remove plug in front of rear wheel. Someone pulls at front and someone pushes from back. Then the deutsch connectors will come out the front of the bike out of the backbone. I haven't done it yet, but have done hours of reading to make sure I have the process down. I also have service manual for a little added comfort!
Mine came with the ends already on, I just had to do the plugs. If you have a street Bob the connections are right at the neck like mine were, Look under the back bone up at the neck and there is a plastic cover you pop out and everything is right there, No need tpush or pull any cables, You dont have tomove the tank or lift it, I didnt even have to pop out the rubber plugs on the side of the neck Maybe the pic will help, the 2005 ran all the way back to the rear, 2006 are simple. Someone was thinking...
[IMG]local://upfiles/24219/D9DA456210D84C26899E44BDB1A0D14C.jpg[/IMG]
Old Feb 9, 2007 | 07:19 PM
Trotter's Avatar
Trotter
Here's the 12.5 chubbys I Installed, much better with the added width
[IMG]local://upfiles/24219/FAC204DCE47D44948FE44E963F5AF12E.jpg[/IMG]
Old Feb 9, 2007 | 09:39 PM
glideridemike's Avatar
glideridemike
My frame plug is bit smaller but I'll pul that our further and see, but I looked in there and it looks like the harness goes beyond that. I'll check it out further in the a.m.
Old Feb 9, 2007 | 09:45 PM
Trotter's Avatar
Trotter
Make sure you look under the top of the frame and not the rubber plug on the side of the frame. I'd nevernoticed it there before.
Old Feb 9, 2007 | 10:03 PM
glideridemike
ok, never looked on the bottom of the upper tube.
Old Feb 9, 2007 | 10:26 PM
Trotter's Avatar
Trotter
Thebestof? should have the same as mine, 2003 might be diffrent... I think the change was in 2006 and up Dynas.
Old Feb 10, 2007 | 07:14 AM
glideridemike
03 wide glidesmust be different. I ran my hand the full length of the upper frame tube and there is no access plug hole. Only the side rubber plug that the harness is tie wrapped to. Therre is a smaller round hole on the bottom of this tube towards the back. I stuck my finger in there and there must be another channel inside the top of the frame member because at that point I could not feel the harness.
Old Feb 10, 2007 | 09:06 AM
Trotter's Avatar
Trotter
Looks like the cut the ties and push & pull Project. The 06 and up redesign makes it real easy Good Luck with this weather you got plenty of time
Old Feb 10, 2007 | 09:13 AM
glideridemike
really, seems like nothing good ever comes easy...at least there's one thing good about this freaking weather, it gives me time.
thanks
