fork Preload Adjusters
Old Feb 12, 2013 | 09:49 PM
ryderbiker's Avatar
ryderbiker
By the way, I'm running ricors with the single rate spring and the difference is amazing compared to the variable rate springs on the market.
Old Feb 12, 2013 | 09:56 PM
SLV's Avatar
SLV
You just answered my next question. Thanks.
Old Feb 12, 2013 | 10:14 PM
SLV's Avatar
SLV
OK. Now I have new questions.
Did you still use the lighter oil for the Ricors? I guess it's necessary.
Did you take a 1/2" off the spacer length calculation to accommodate for the Ricors?
Thanks.
Old Feb 12, 2013 | 10:36 PM
El Chiguete's Avatar
El Chiguete
..to obtain the proper preload if you're over 180lbs..
So what is the proper preload for the riders weight? I changed the old ¨liquid¨ (since it was so old and degraded that I can't even call it oil) to Screaming Eagle and it made a big difference but still I'm sure its not where it should be.
Old Feb 12, 2013 | 11:02 PM
ryderbiker's Avatar
ryderbiker
Preload will vary depending on the rider. You basically want the sag, with you sitting on the bike, at 1/3 of the total suspension travel. For simplicity, say you have three inches of travel you'd want the laden height of the suspension to be 1" lower than the height at full extension. There are tons of articles online of how to measure sag.
The springs I'm running are about 3" shorter than the stock springs. Initially I added that difference minus the 1/2" for the ricors and I couldn't compress the caps within 2" of the fork tubes. I'm running a 1kg single rate spring which is much stiffer than the .96kg variable rate spring that's stock. It may not seem like a huge difference, but a variable, or progressive spring has a much softer section that compresses easily before it gets into the stiffer section of the spring. I ended up running a 7" spacer, which was the tallest I could run and still get the fork caps on. My sag is about 3/4" to soft and the adjusters will make up for that.
I'm running 10wt Amsoil Shock Therapy. My ricors are stock but they will be getting modified with new shim stacks and valve porting. Once that's done I plan to change to 5wt Amsoil. Every fluid comes out differently on how they measure viscosity and no one has convinced me that there is a better fluid than Amsoil.
I have a pretty in depth thread in this setup that explains why it works. The link is below. I talked to many suspension companies and none of them agreed on what was best. This is my 5th fork setup and is by far the best. I don't think it would compare to Ohlins cartridges, but it cost about $600 vs $1500.
https://www.hdforums.com/forum/dyna-glide-models/764904-front-suspension-upgrade.html
Old Feb 13, 2013 | 08:08 AM
rhoderider's Avatar
rhoderider
They are cool. Never seen them on anything but sport bikes. I really can't see spending that kind of money on the adjusters when you could use it for better springs. Like someone said, once you get your pre-load doped in then there should be no reason to touch it (at least I can't think of any).
Old Feb 13, 2013 | 11:04 AM
ryderbiker's Avatar
ryderbiker
The issue is that with "good springs" it's extremely difficult to compress the springs enough to gain the proper amount of preload. The adjusters allow you to use a shorter spacer which makes it easier to compress the springs and then adjust the preload to properly set the sag. I think I said that already.
Old Feb 13, 2013 | 11:23 AM
HD Pilot's Avatar
HD Pilot
Hey ryderbiker, I think you are using the Intiminators modified by Fabrik8r? How does this help on the Dynas vs Touring that his thread is written about and how much is the mod? Sorry to sidetrack this thread a bit.
Old Feb 14, 2013 | 02:25 AM
Aussie XB12SS's Avatar
Aussie XB12SS
Originally Posted by EricInNCa
I have been looking into these and cannot seem to find anyone who has the RSD ones in stock. I'll be adding them when I can locate some.
Same here. Just got an email saying another month before in stock.
Old Feb 14, 2013 | 05:16 AM
rs87277's Avatar
rs87277
everything RSD is a month out, then they tell you another month........
