fork Preload Adjusters
Old Feb 12, 2013 | 10:11 AM
El Chiguete's Avatar
El Chiguete
Default fork Preload Adjusters
So who is going to go out and try this first? http://blogs.streetchopperweb.com/th...#axzz2KhZbZyZq btw, they make 39mm ones too.
Since I have a '93 Wide Glide I would need this http://www.ebay.com/itm/NEW-SHOWA-41...-/290614947199 but its the same idea but in 41mm.
Since I'm not a suspension expert I would love that one of you guys tried them out and give us your feedback.
PS:
This with a set of Ricor Intimidators would make for a killer setup no?
Old Feb 12, 2013 | 10:17 AM
EricInNCa's Avatar
EricInNCa
I have been looking into these and cannot seem to find anyone who has the RSD ones in stock. I'll be adding them when I can locate some. I also have the Ricor Intimidators already installed. Should be a sweet setup.
Old Feb 12, 2013 | 02:29 PM
rooti's Avatar
rooti
I don't really understand spending 150 bucks on that...Once you get your front end dialed in there would be no more reason to adjust them.
Old Feb 12, 2013 | 05:14 PM
DoubleZ's Avatar
DoubleZ
I wanna get the speed merchant ones. And see what kind of difference they make on a stock front end
Old Feb 12, 2013 | 06:05 PM
SLV's Avatar
SLV
I just got mine yesterday. They go on this weekend. I have stock springs for now.
Old Feb 12, 2013 | 07:01 PM
Puffdaddy's Avatar
Puffdaddy
I'm looking forward to any reviews as well. I have the Ricor Imtiminators up front, but it still leaves a lot to be desired (compared to the Ohlins out back)
Old Feb 12, 2013 | 07:48 PM
fat bastard 68's Avatar
fat bastard 68
I'm interested also, I also have the Ohlins and I have to do something about the front end now tis *****!
Old Feb 12, 2013 | 07:52 PM
El Chiguete
Looking forward to the weekend reviews! now who will do one with a pair of Ricors on???
Old Feb 12, 2013 | 07:53 PM
El Chiguete
Yeha I feel the same with the Works shocks I have on mine, as soon as I put them in the front fell like ****!
Old Feb 12, 2013 | 09:47 PM
ryderbiker's Avatar
ryderbiker
I'm planning to get the speed merchant adjusters after battling with my preload spacers when changing to my new front end set up. If you run a single rate spring, which if your running anything other than Traxxion Dynamics springs you're not, it is a pain to compress the fork caps with the amount of spacer needed to obtain the proper preload if you're over 180lbs. You can add and inch and half of preload and get your sag adjusted correctly to allow the forks to operate in the correct range of travel for your weight. I spent 2 hours cutting and re-cutting the spacers and fighting with the caps before I cut them to a length that enabled me to install the fork caps and decide I would add the adjusters to make up the difference.
