Exhaust Flange Nuts - Huh?
Old Feb 10, 2007 | 08:03 PM
danieldd's Avatar
danieldd
Default Exhaust Flange Nuts - Huh?
Well, this is strange and I can't figure it out. Last weekend I took the exhaust system completely off so I could put on a chrome cam cover and transmission side cover. Today I finally get around to putting the pipes back on. Here's the strange part.. The flange nuts. It appears two of the flange nuts go on quite easily, the other two don't. I get a thread or two on and they tighten up quick. I look closely at the nuts and it looks like two of them are captive nuts. These two nuts are dippled on two of the shoulder sides. I looked in the manual and it says nothing about different nuts. What is up with this? Anybody else experience this issue? I'm figuring each of the exhaust flanges need one regular nut and one captive nut. If this is true, then which flange stud does the nut go on?
Any help in this area would be greatly appreciated.
Old Feb 10, 2007 | 08:09 PM
Trotter's Avatar
Trotter
Default RE: Exhaust Flange Nuts - Huh?
Go Get 4 New Nuts !!! You DONT want to cross thread or damage the studs..
Old Feb 10, 2007 | 08:12 PM
danieldd's Avatar
danieldd
This isn't a cross threading issue - rather this is an issue of determining the proper nut application. If no one can answer this little puzzle, then I'll certaintly take your advice and get new nuts. Thanks.
Old Feb 10, 2007 | 09:10 PM
vdubpig's Avatar
vdubpig
Dude!! I had the exact same problem when I switched mine out to V&H pipes.. two nuts went on great, and the other two started to cross-thread, and when we switched em they went on better. There's some shenanigans afoot... I'd get two nuts that go on easy at the ol' hardware store. I battled with getting mine on carefully and it took a while.
Old Feb 10, 2007 | 09:26 PM
danieldd's Avatar
danieldd
Okay. We got a consensus, so I'm not nuts about my nuts!
Maybe someone can enlighten us?
Old Feb 10, 2007 | 09:42 PM
Trotter's Avatar
Trotter
Mine have always been the same ,,, unless I've been lucky the last thirty years
Old Feb 10, 2007 | 09:59 PM
HOGRIDA_06's Avatar
HOGRIDA_06
ORIGINAL: danieldd
I'm nuts about my nuts!
Old Feb 11, 2007 | 12:41 AM
thebestofindica's Avatar
thebestofindica
When I put the T-header on, the rear flange bolted up fine, but the front one was a bear. I believe they are standard fine thread. I swapped out the front two as they were making me nervous.
Old Feb 11, 2007 | 02:35 AM
waterman7474's Avatar
waterman7474
OK, i thought i was crazy the crazy one!!!
i swear i had the same problem with the rear head. i swear, the rear-rear nut must have taken me 30 min to get on.
Old Feb 11, 2007 | 12:04 PM
haksaw's Avatar
haksaw
no problems on my fxdbi. All nuts were the same
