you can not just flush it... very important that you do flush this out as it will begin to shrink the seals and also could begin to get into a jelly like state. when you change the fluid, i would HIGHLY recommend seal replacement all around (master and calipers) then flush the lines with denatured alcohol. if you do not replace the seals at least pull them and clean them really well in the denatured alcohol as well
I don't see how DOT 4 would flush all the DOT 5 out or vice versa, because they're not compatible? It's why flushing DOT 5 out (with DOT 5) doesn't remove the water trapped in various nooks and crevices in the fittings and calipers. Alcohol is probably a solvent for both types of fluid.
it is the only thing that is approved to clean them. personally if this has been like this for 4 months i would never flush i would replace the lines, seals, and wash all the hard parts really well in denatured alcohol. If a customer insisted on just flushing i would refuse the work due to liability. i do not mess around when it comes to your brakes i have had them lock up on me and send me flying. never again. do it right, do it once
^^this is probebly the best suggestion in this thread.
+1 you need a service manual if you plan on doing your own maintenance and repairs. At least pick up a Clymer manual.
Heck yeah, my service manual is getting broken in nicely. It wouldn't be a real service manual without blood and grease on the pages.
I'm at work now and couldn't check the manual since it's at home.
I will say if you are not comfortable doing this, you can send them to me i can rebuild your master and calipers... it may be a good time to shave them and add some powder as well
You should also break in your owners manual, a little, too. It tells you what brake fluid to use.
After 20+ years as an auto tech, I've seen this many times...Like Joe stated...Take apart and rebuild. All rubber is crap for sure. Pretty simple job and not worth the risk seeing that it is your brakes. Normally when someone adds the wrong fluid to a brake system, the seals swell causing the brakes to apply and lock up.
