Brake fluid mistake!
Old Feb 28, 2013 | 05:08 PM
  #31
DanDman's Avatar
DanDman
Joe, is there any part you don't modify and coat? All the parts you post are trick. I'm going to have to PM you with an idea I have for a timer cover. I can't find any local powder coater's with the attention to detail like you have
Old Feb 28, 2013 | 05:31 PM
  #32
JRK5892's Avatar
JRK5892
hahaha if it will tkae the heat... we coat it!
Old Apr 7, 2013 | 10:58 PM
  #33
Humble's Avatar
Humble
6th Gear
I just installed a new brake line and put DOT 4 in and bled the brakes,then i realized i had put in the wrong darn fluid! I then emptied the MC by dumping it out and replaced with DOT 5 and flushed. Do you all think this will be okay or do i have to use alcohol to flush it out?
Can i just empty the MC and fill it with denatured alcohol and bleed it??
Old Apr 8, 2013 | 09:05 AM
  #34
Ridewva's Avatar
Ridewva
You can't totally bleed one out with the other. Personally I would rebuild the MC and calipers, then flush the lines with alcohol (or replace them) using the opportunity to be rid of the DOT 5.
Old Apr 9, 2013 | 07:48 PM
  #35
Humble's Avatar
Humble
6th Gear
I need to keep the DOT 5. I fixed what i had originally said. I called a few shops and they said since i did it all in the same day i should be ok because there should only be minute traces of DOT 4 left in the system and the DOT 4 was not in the system long enough to cause any real damage to seals etc. SOund reasonable?
Mohammed Alyahya
Apr 11, 2019 03:21 PM
rlchristensenmd
Wheels/Tires
Sep 14, 2009 03:05 PM
atrain68
Wheels/Tires
Apr 9, 2009 07:37 PM
HDF Tech
Feb 26, 2006 03:26 PM
HDF Tech
Feb 26, 2006 03:18 PM
