'10 fat bob brake light stays on
Old Mar 2, 2013 | 09:03 PM
Harleycoastie's Avatar
Harleycoastie
3rd Gear
Default '10 fat bob brake light stays on
Hi my 2010 fat bob brake light will not go off. How can I fix this?
Old Mar 2, 2013 | 09:07 PM
Juan L's Avatar
Juan L
Moderator
First you have to isolate which one it is front or rear. Disconnect wires from rear brake pressure unit on rear brake line. If light goes out that's it, if not check front brake handle. Inside the housing is a little contact, see if it is broken.
Old Mar 3, 2013 | 12:40 AM
Scuba10jdl's Avatar
Scuba10jdl
Probably broke your front brake switch. Do any work on the bars or take apart the switches lately?
Old Mar 3, 2013 | 09:14 AM
Northbound Southerner's Avatar
If you have taken your levers off, did you wedge the front switch? If not, you probably broke the little nub...
Old Mar 3, 2013 | 01:25 PM
Harleycoastie
3rd Gear
I isolated it to the front. I have never touched the front brake or lever. The bike only has 2000 miles on her. If I pull the lever forward and wiggle it around the brake light goes off for a sec or two. Could the switch be stuck?
Harleycoastie
3rd Gear
If the switch is bad are the expensive to replace? I can do the work myself.
Old Mar 3, 2013 | 01:40 PM
128auto's Avatar
128auto
71621-08 front stoplamp switch $59.99
Old Mar 3, 2013 | 04:29 PM
They aren't expensive but are a PITA to replace...
Old Mar 3, 2013 | 04:30 PM
I does sound like the nub on the switch is broken off...
Old Mar 3, 2013 | 04:35 PM
izzyryder's Avatar
izzyryder
I had the same problem with my fat bob and just fixed it. It's a bad master cylinder that's not returning the brake lever out all the way.
The brake light is off when the lever is pushed out and, in turn, pushing in the brake light switch. So what happens is when the master cylinder piston is failing it does not push the lever out all the way and makes the brake light either stay on or flicker.
You can get a master cylinder rebuild kit from harley or after market.
