Front Brake line bolt at Master Cylinder?
Old Mar 4, 2013 | 10:37 AM
Steel Steed's Avatar
Steel Steed
Default Front Brake line bolt at Master Cylinder?
What kind of bolt/nut is that? It seems to be just smaller than a 1/2", but I don't have any sockets like that.
My brake line has a crack in it and has to be replaced.
If you know what size/type socket I need for this, post it up! I'll pick up the tool after work today.
Attached Thumbnails Front Brake line bolt at Master Cylinder?-brakelinebolt.jpg
Old Mar 4, 2013 | 10:44 AM
DCLXVI's Avatar
DCLXVI
It is just a 12 point socket.
Old Mar 4, 2013 | 11:06 AM
Gommee's Avatar
Gommee
Devil's Advocate
It is a METRIC 12 point socket.
Does not hurt to have a set of them. I think mine are Craftsman. Check Harbor Freight in US and Princess Auto in Canada for an inexpensive set.
It makes my day when I can add a new tool to the collection!
Old Mar 4, 2013 | 11:14 AM
19jake91's Avatar
19jake91
I used a 7/16 12 point socket on mine. It fit well.
Old Mar 4, 2013 | 11:52 AM
Gommee's Avatar
Gommee
Devil's Advocate
Good to know, up here I have doubles of everything SAE and Metric. You never know what you are going to need.
When ever I work on the brakes, I pull out the metric sets, they seem to fit the brake bolts snugger.
Old Mar 4, 2013 | 12:01 PM
Northbound Southerner's Avatar
It's an 11mm 12 point
Old Mar 4, 2013 | 12:06 PM
Gommee's Avatar
Gommee
Devil's Advocate
Thanks for the clarification, I thought it was 11 mm, but being at work at the moment, I could not confirm.
I do know (according to HD Manual) that the main caliper bolts are 10mm.
Old Mar 4, 2013 | 04:44 PM
ilmonster's Avatar
ilmonster
6th Gear
And the banjo bolts should be torqued to 17-22 ft/lbs, both on the master cylinder and caliper.
And be careful, Dot 4 brake fluid is a great paint remover!
Old Mar 4, 2013 | 08:37 PM
Steel Steed
Thanks! Great info about the torque. Is that in the service manual?
Old Mar 5, 2013 | 09:36 AM
Scarfmace's Avatar
Scarfmace
Thats what I used. Should fit perfect
