Burly Slammer kit, too low? Advice?
Old Jan 22, 2016 | 07:48 AM
  #31
HrdNox's Avatar
HrdNox
I just wanted to see who brought this thread up from the grave.
Old Jan 22, 2016 | 08:09 AM
  #32
Keegan5's Avatar
Keegan5
5th Gear
Arrow
That would be me sir.
Old Jan 22, 2016 | 03:22 PM
  #33
BigDogIdaho's Avatar
BigDogIdaho
Is that a Road King you have there? If so this might be a better question over on that side.
I would think it would be just fine though. I don't think the forks can compress that much even with shorter springs in there.
Old Jan 23, 2016 | 08:20 AM
  #34
Keegan5's Avatar
Keegan5
5th Gear
Thanks for the advice and the input, much appreciated..as you can tell I'm still learning my way around the forums.
Old Jan 23, 2016 | 04:52 PM
  #35
BigDogIdaho
No problem! Just wanted you to get the correct info. Welcome to the forums!
Old Feb 11, 2016 | 07:40 AM
  #36
jricharc's Avatar
jricharc
Any thoughts on lowering the front end? I have 11" rear shocks and I scrape on tight turns but that was when I had mids. I have switched to forward controls over the winter and have been thinking about dropping the front too.
Here is a pic before the forward controls.
Old Feb 11, 2016 | 11:03 AM
  #37
jmeiers's Avatar
jmeiers
I have the Progressive drop-ins on the front of mine (dropped over 2 inches) and I do not scrape with forwards. However, I do have Arnotts air ride in the rear and I typically ride with them pumped up so I have closer to stock clearance in the rear while riding.
Old Feb 11, 2016 | 11:56 AM
  #38
HrdNox's Avatar
HrdNox
You could also help the look by snugging up your front fender to your tire a bit.
Old Feb 11, 2016 | 04:51 PM
  #39
jricharc's Avatar
jricharc
How can you do that? Elongate the holes?
BudTheGrey
2014-2024 Touring Models
Apr 27, 2019 09:04 AM
Pixiechitos
Jan 15, 2013 07:43 AM
JimmieJack
Mar 26, 2010 01:23 AM
MechsHands
Mar 11, 2010 05:08 PM
sportyshorty
Jun 3, 2006 08:18 PM
