Wide Glide fork
Old Mar 8, 2013 | 03:00 AM
zhalvaje's Avatar
zhalvaje
Default Wide Glide fork
I have a Burly slammer kit sitting in the garage waiting to be install on Saturday, the rear shocks are easy to install but i have a question on front springs. Is it a drop in springs or do i need to disassemble the forks in order for me to install the springs? Please help. Thank you...
Old Mar 8, 2013 | 05:16 AM
HarleyBob52's Avatar
HarleyBob52
I have put new springs on my wide glide (2003). The forks need to be removed from the bike to install. But they do just "drop in" the top of the forks. No need to disassemble the forks. Be careful with the fork tube top caps,use the right tool to remove,or you will f... them up. Guess how I know that??!!!
Old Mar 8, 2013 | 09:41 AM
nosparkoflife's Avatar
nosparkoflife
this video isnt the most informative but it gives you a general idea.
Old Mar 8, 2013 | 12:51 PM
jmeiers's Avatar
jmeiers
No you do not need to remove the forks to install. Jack the bike up so front tire is just off the ground (suspension fully extended). Then, if your bars are in the way of the fork caps, either loosen them or remove them and lay them on your tank (with a towel there first to prevent scratching). Finally, just loosen the pinch bolts in the top tree. That is it!
Be careful taking the fork caps off. Make sure you got control of them after undoing the last thread. I covered them with a towel and applied pressure during the last threads of removal until they "popped" off. If you don't be careful, they could fly out on you. This only applies if your forks still have stock springs in them. Once you put in lowering springs, the pressure is not bad the next time you take them off.
Old Mar 8, 2013 | 01:00 PM
dirtdobber's Avatar
dirtdobber
For me I like to change the fork oil when doing the fork springs. This is regardless of miles.
it will save you some time later on.
just a thought.
Old Mar 8, 2013 | 02:44 PM
HarleyBob52
Be careful taking the fork caps off. Make sure you got control of them after undoing the last thread. I covered them with a towel and applied pressure during the last threads of removal until they "popped" off. If you don't be careful, they could fly out on you. ThisI only applies if your forks still have stock springs in them. Once you put in lowering springs, the pressure is not bad the next time you take them off.
I guess it is pretty model dependant. On my 03 wide glide removing the fork caps will not get you to the springs. You must remove the forks and then unscrew a plug from the top of them to get to the springs. OP said he had a WG but not the year
Old Mar 8, 2013 | 04:19 PM
zhalvaje's Avatar
zhalvaje
Do i need to install the 2 small springs that comes with it? and what about the PVC pipe? do i need to cut them? thanks
Old Mar 8, 2013 | 04:41 PM
jmeiers's Avatar
jmeiers
It's been 3 years since I did it but there should be a longer spring and a shorter spring for each fork. Longer spring first then the smaller spring then a flat washer and then the PVC spacer on top. The length of the spacer is what determines the overall ride height.
I only run a 1/2" spacer in my street bob and my drop is over 2". Your spacer will be longer to account for the rake of wide glide. The instructions explain this.
Longshot USMC
Jul 7, 2014 11:09 AM
Ncdyna925
Apr 9, 2013 01:18 AM
cykodad
Mar 26, 2011 02:40 PM
doer
Jan 27, 2011 08:59 AM
MJ
EVO
Jan 13, 2008 02:14 PM
