Help with new front fork springs
Old Feb 14, 2007 | 03:03 AM
clayman's Avatar
clayman
Default RE: Help with new front fork springs
Thanks Mud, i do have the manual, but it really only shows how to tear it all apart and not to do a specific job like lowering.
So once i loosen the pipe screw then take off the cap and drop the spring and oil, now take the pipe screw out and the damper tube will come out as well ? at this point is that where i stop and install the progressive parts and put it back together. Are ther parts or seals that will be damaged by this.
Thanks for the help Mudd
Old Feb 14, 2007 | 03:33 AM
mud's Avatar
mud
ORIGINAL: clayman
Again, I haven't done the lowering kit, so I don't know what parts come along.
Yeah, the 12mm screw releases # 23.
Pic below, I would replace # 13, 16, 18, and inspect # 20 (replace, if ugly).
(All may not need replacing, I would anyway, cheap enough.)
mud
Old Feb 14, 2007 | 03:39 AM
clayman's Avatar
clayman
Thanks again Mudd i will let you know how i make out tommorow,
K33b
Feb 13, 2024 04:30 PM
TexFF
Jun 3, 2013 11:56 AM
Ncdyna925
Apr 9, 2013 01:18 AM
lowriderrob
Oct 21, 2009 02:31 PM
stang2811
Mar 31, 2008 06:56 PM
