stock riser height on the bob?
Old Feb 13, 2007 | 10:23 PM
waterman7474's Avatar
waterman7474
Default stock riser height on the bob?
as some of you may have read, after my new gimp acquisition, i have room for another inch in my cables so i wanna go +1 in a riser. the thing is, i don't know what the stock ones are classified as so that i can order ones that are only 1 inch bigger?
did a search but didn't find.
Old Feb 14, 2007 | 12:27 AM
lolife's Avatar
lolife
Default RE: stock riser height on the bob?
sup waterman...........................I have no hard facts...............Ive been told that the riser is a 2".........If you measure from bottom to center it is 2"......maybe you want a three inch riser.......................LO.................... .
Old Feb 14, 2007 | 01:55 AM
Angry_Monkey's Avatar
Angry_Monkey
How had are those to install??
Old Feb 14, 2007 | 12:02 PM
lolife's Avatar
lolife
ORIGINAL: Angry_Monkey
easy...................very easy.......................hey waterman....when you put the bars on did you change to a poly bushing.?..................helps with flex................also keep in mind when you have tall bars and add a tall riser, you will have more flex....................LO........................ .......
Old Feb 14, 2007 | 01:45 PM
DA ROOSTER's Avatar
DA ROOSTER
I just did a Gimp change. Stock to 12inch, I put the poly bushings in anda big difference in feel. The one thing that I did notice was a major increase in Handlebar vibration. I am guessing that is because of the stiff bushings. To me that is the only down fall to the poly bushing.
Old Feb 14, 2007 | 01:58 PM
metal_mike's Avatar
metal_mike
ORIGINAL: DA ROOSTER
did you need longer cables/wiring to use the gimps?
if so how long?
mcrackin
Apr 17, 2017 07:53 PM
BFDHD14
Nov 5, 2013 03:04 PM
EasyMoney1027
Jan 22, 2012 03:39 PM
El Jinete Fantasma
Feb 27, 2009 11:36 AM
PsTaN
Jun 25, 2006 02:47 AM
