Twin Cam 88 upgrade: Considering the switch to a hydraulic cam tensioner system
Forum member Spanner has been very informative as to what my options are, and based on his input I've come up with the following plan. Please check it out and tell me what you think:
1. I'll replace the spring-loaded tensioners with new ones just to be safe another 20,000 miles or so.
2. I wanted to switch to gear driven cams, but since there is the possibility of crank runout in an engine with that many miles, and since the country I live in (Honduras) doesn't seem to have shops that can weld and true the crank installing gear-driven cams without truing the crank would be a bad idea. So scratch that. (If I ask around machine shops they will say they can do it just so they can get the job, and probably botch my crank in the process)
3. In the end, like Spanner has said, the most viable option is to make the switch to the hydraulic cam tensioner system. I'm considering the SCREAMIN EAGLE HYDRAULIC CAM CHAIN TENSIONER CAM PLATE OIL PUMP KIT part# 25284-11 since it already comes with the oil pump upgrade I need to install. If you know of any other aftermarket option, PLEASE let me know.
However, for this particular kit to work, the instructions say I need additional parts:
- Spacer Kit P/N 25285-08
- Cam Service Kit P/N 17045-99D
- Drive Gear Retention Kit P/N 25533-99A.
How true is it that I need these so-called extra 'kits"? Or is it a ploy from Harley to get more money? As far as I know they're only washers and o-rings, does anyone know? Thank you very much for your help and input on this matter, it's critical!
I have put this kit in two of my bikes and it has worked great in both. I am yet to pull the cover and check the tensioner shoes since the install and it has been quite a while so one of these weeks I will get to that.
If you put in adjustable push rods then you really don't need teh cam service kit but you will need a new cam cover gasket. I always order my inner and outer cam bearings separately.
Yeah, I'm planning on keeping the same pushrods, so I'll need the cam service kit after all. What worries me though is that in most of the service videos I've seen the pushrods are cut with a wirecutter and then replaced with adjustable or EZ pushrods after the cam system has been installed. I guess they just do it because it takes less time than disassembling the pushrods themselves.
...and taking advantage that the cam plate will be down, I should change the bearings while I'm at it, but I'll need the $190 dollar tool to do so...
The total for tools and parts is around $1,050. I'll be buying the spring loaded tensioners so I can start on the rest as soon as possible. I'm not really sure on what I should tackle first though, probably making the switch to the hydraulic tensioners should be my first step.
