Pc-v ?
Old Mar 23, 2013 | 08:49 AM
dmpjr's Avatar
dmpjr
Default Pc-v ?
I installed my PC-V that I purchased from Fuel Moto with a preloaded map. I have a Stage 1 ac from DK and Sampson BG3 pipes. I have only put about 10 miles on it since the install and I really notice an increase in power and decel pop is completely gone. The only problem I gave is a just off throttle hesitation..worse when cold but still there warm. It seems to be at about 1400 rpm's. Id I cruise at 1400 rpm's, it almost feels like it's surging. My question..is there an adjustment I can make to cure this? Its annoying.
Old Mar 23, 2013 | 11:12 AM
dirtdobber's Avatar
dirtdobber
Call em and they will send you.a new map, free.
Life time maps from them.
Old Mar 23, 2013 | 11:23 AM
Junkster's Avatar
Junkster
+1 Call Jamie he will fix ya up. Look into the Auto Tune option. Works great.
Old Mar 23, 2013 | 11:33 AM
dmpjr's Avatar
dmpjr
What does the auto tune option entail?
Old Mar 23, 2013 | 01:10 PM
Junkster's Avatar
Junkster
Its a module add on with wide band 02 sensors. Automatically tunes your bike. Adjusts AFR on the fly. I have the PC-V +AT on my dyna and it works great. Added cams it made the adjustments. Elevation changes etc it makes the adjustment. Cold to hot etc. You get the idea. Only problem its like 300 greenbacks.
Old Mar 23, 2013 | 01:52 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I would add that 1400 RPM is in the lugging range for cruising, the "surging" you're feeling may be the primary because of too low of RPM for cruising.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Mar 23, 2013 | 01:59 PM
dmpjr's Avatar
dmpjr
No, it's a flat spot for sure at 1400-1500 rpm
Old Mar 23, 2013 | 02:03 PM
nevil's Avatar
nevil
That's too low in the rpms to be cruising. You need to be in a lower gear, at least another 500-600 revs.
Old Mar 23, 2013 | 02:12 PM
128auto's Avatar
128auto
+1 He is lugging not cruising
Old Mar 23, 2013 | 02:15 PM
Junkster's Avatar
Junkster
If your in a lower gear (not lugging) and its still doing this call fuelmoto. Maybe too lean in that rpm range.
