Stock throttle lock: Who uses it?
Old Apr 8, 2013 | 10:06 PM
  #31
arkstreetbob's Avatar
arkstreetbob
I got a lever off ebay for around $15.00. It works great! I use it on long rides so my hand and wrist dont ware out. Got a plate and 10 screws in my right wrist last Sep. so I needed some help.
Old Apr 8, 2013 | 10:21 PM
  #32
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Originally Posted by Jonesee
Damn. U da man. How many hours can you hold that throttle open without a break?
Oh my shoulder craps out way before my hand resting on a grip will. It's just sitting there...like my butt on my seat!
Old Apr 8, 2013 | 11:30 PM
  #33
RonnR's Avatar
RonnR
Originally Posted by Shrug
I use mine often with a ThrottleMate attached for quick engaging and release.
Same here Scott, works great for me..
Old Apr 8, 2013 | 11:51 PM
  #34
Id.Fat Bob's Avatar
Id.Fat Bob
On my older Harly's, I used it to maintain fast idle during warm up! They are built well in that the threaded shaft tightens down on a small shoe similar to a train wheel brake. One has lasted 120 K on one bike I know and surely many more! Never used it on my FB so far due to it being injected and controles the fast idle during warm up!
Old Apr 9, 2013 | 12:12 AM
  #35
Squirrel67's Avatar
Squirrel67
A zip tie works well enough just wrap it around so it is flat (not verticle) and cut to length. and a whole lot less than a throttle mate.
Old Apr 9, 2013 | 12:55 AM
  #36
DeJavu's Avatar
DeJavu
Cool
My chopper tends to flood easy on cold starts. If I can't get it started in 3 or 4 kicks, I use the brake to open the throttle just a hair to get a little more air through the S&S E.
Works most of the time.
Old Apr 9, 2013 | 01:07 AM
  #37
baka1969's Avatar
baka1969
I use this:
http://www.amazon.com/gp/aw/d/B004VR...sr=8-1&pi=SL75
Old Apr 9, 2013 | 02:11 AM
  #38
FBFletch's Avatar
FBFletch
As others have pointed out, the stock throttle lock works. However, to me, it's a PITA to use.
I installed a BrakeAway throttle lock:
http://www.brakeawayproducts.com/
Yes, they're brutally expensive - a lot more money than most folks are willing to pay for a throttle lock. But, if true cruise control isn't an option, the BrakeAway throttle lock is the next best thing IMHO.
I can set mine easily wearing the thickest gloves I own (just a push of the thumb). And, it disengages with either a push of the thumb or by applying the front brake. Easiest throttle lock I've ever owned. And, the only throttle lock I'll ever own.
To me, the only downside to the BrakeAway (aside from the price) is that when I bought mine you could only get them for 1.5" diameter grips (many of the optional grips offered by Harley are larger than 1.5" in diameter). Make sure you measure your grips before ordering or go to the Harley dealership and measure any grips you may be interested in purchasing.
Old Apr 9, 2013 | 06:58 AM
  #39
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I keep mine snug on the Dyna, so I can let go and the setting doesn't change, yet easy to bump up or down as conditions warrant. I like to give both hands a break now and then, sometimes even both at once. I ride with fairly thin gloves if it's below 60-F., and operating the star-wheel is not an issue.
Old Apr 9, 2013 | 08:46 AM
  #40
Tampakingpin's Avatar
Tampakingpin
Don't use it. Fiddle with it once. I ride with high apes and never think about that thing. Out of sight, out of mind
