Is compression release mandatory for 107 build?
Old Apr 9, 2013 | 07:28 AM
SLV's Avatar
SLV
Don't forget that the compression ratio is just that, a ratio. It represents the ratio between your combustion chamber's largest volume to it's smallest volume. As a result, a 10:1 ratio in a 88" motor requires less force than 10:1 in a 107" motor. In other words, as displacement increases, assuming the same ratio, the force required to compress the gasses increases. Unless your starter-motor torque increases porportionally with the displacement, it will work harder to crank the motor.
Simplifying the equation to compression ratio vs cranking power alone doesn't work.
Is it required? Probably not. Will the added displacement increase resistance on your starter? Yes.
A compression release alleviates a great deal of the required cranking torque.
Old Apr 9, 2013 | 07:43 AM
Danofxdx's Avatar
Danofxdx
S&S easy start cams and no compression releases, I love it, the only down side I see is that I can't do a compression check
Old Apr 9, 2013 | 10:52 AM
128auto's Avatar
128auto
Thanks for all your inputs!
FM charges an additional $100 for compression release installed which is a great deal.
I live too far away from FM, shipping those heads alone costs me $100 at least. I found a local Harley shop charges $200 for the pair ACR, really expensive. They charge $1400 for a pair of head porting and bigger valves, ridiculous! Wish I live in states, much better deal and quality work.
Old Apr 9, 2013 | 11:04 AM
Scrmnvtwins's Avatar
Scrmnvtwins
While you have it down, put them in, your starter will last longer
Old Apr 9, 2013 | 11:57 AM
soft 02's Avatar
soft 02
Ouch! Local guy charges $50 and I provide the CR's.
Old Apr 9, 2013 | 12:26 PM
128auto's Avatar
128auto
I am wrong! Just called them, $200 is for manual release, the auto compression release is $165 per head plus parts. WTF!!!!!!!!
Old Apr 9, 2013 | 12:39 PM
soft 02's Avatar
soft 02
ACR's themselves are much more espensive and you have to wire them into the harnes. For that price you could just buy the jig and sell it when your done. I think the jig is like 250.
Old Apr 9, 2013 | 12:41 PM
Gommee's Avatar
Gommee
Devil's Advocate
It would be cheaper to buy the tool and do it yourself.
Old Apr 9, 2013 | 12:53 PM
ReapersWG's Avatar
ReapersWG
Better to have them then need them. What is your cold cranking pressure right now? Go to Big Boyz's website and put in your build info in the twin cam calculator this will give you a general idea. If you end up with 190 or higher I'd go with releases but my first statement is also true too. Hope this helps
Old Apr 9, 2013 | 01:07 PM
soft 02's Avatar
soft 02
Good idea!
