Is compression release mandatory for 107 build?
Old Apr 9, 2013 | 01:10 PM
128auto's Avatar
128auto
Well if that is the case, I might just get B heads from FM with compression release installed. The jig thing isn't easy, have seen it on youtube, you need a powerful drill to do that, beyond my skill lol.
How do you wire them? I thought the wiring harness came with the bike, can I program it with my PV?
Originally Posted by soft 02
ACR's themselves are much more espensive and you have to wire them into the harnes. For that price you could just buy the jig and sell it when your done. I think the jig is like 250.
Old Apr 9, 2013 | 01:13 PM
soft 02's Avatar
soft 02
Your bike is capable but you need to buy the harness and install the pins into the ECU connector then turn it on with your tuner. Isnt cut and dry and if it ever fails the valve covers have to come off as they are in the middle of the head. MCR's are the wat to go IMHO.
Old Apr 9, 2013 | 01:47 PM
JRK5892's Avatar
JRK5892
Originally Posted by vdop
No it's not mandatory, yes it's highly recommended. Manuals are a piece of cake to install, automatics will cost a little more to have done. If you're gonna build it do it right the first time.
this is 100% the spot on answer... i did manual in mine, and well worth it... i also like JP cycles high crank battery or braille battery... but to be honest if you run compression releases the stock HD battery will be just fine
Old Apr 9, 2013 | 02:41 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I don't have a hot build, just a 103 with 255 cams. Bike starts easy when cold, but when it's hot out it can be problem without the CRs. I'm glad I had them installed.
Old Apr 9, 2013 | 03:14 PM
128auto's Avatar
128auto
Question, when you install a compression release, I assume you have to shut off the valves manually after the motor runs, correct?
Old Apr 9, 2013 | 03:24 PM
soft 02's Avatar
soft 02
No. Manual one's you push the button tops befor you start it. The engine's compression closes them.
Old Apr 9, 2013 | 03:33 PM
128auto's Avatar
128auto
Hey, that may not be a bad idea! I just worry about sometimes I forget to shut it off. Do all compression release valves work the same way? Thanks!
Old Apr 9, 2013 | 07:32 PM
target64's Avatar
target64
highly recommend manual releases, after riding when stopping for fuel a few minutes of heat soak and my 107 cranks pretty hard with out hitting the releases. you will be replacing the starter sooner then u want to.
Old Apr 9, 2013 | 07:33 PM
oldlefty's Avatar
oldlefty
pretty much. you have to push them to open them before you start your bike. when the bike fires, the valves slam shut and stay that way until you shut it off. then you press them down before starting again.
Old Apr 13, 2013 | 10:12 AM
128auto's Avatar
128auto
After all, I might get the Jims tool to make my own. Now my question is, how big a drill do I need? The drill bit is quite big but drilling aluminum shouldn't be that bad I guess.
