???mpg???
Old Apr 16, 2013 | 09:10 AM
PistolPete83's Avatar
PistolPete83
Default ???mpg???
Ive got a 2012 fxdc with full exhaust....mach 2 intake...and a PV....im getting around 35 mpg....i mainly ride city and pretty hard but im hearing of others with stage 1 getting 45+.... Why such a difference?? Could it be solely riding style??prior to the stage one as far as i can remember i wasnt ever getting over 45mpg...i havent mounted the PV yet so i cant wait until i do to get more of an accurate reading....
Old Apr 16, 2013 | 09:38 AM
milesvdustin's Avatar
milesvdustin
Well if you havent mounted the tuner yet then your fuel values are all messed up.
Old Apr 16, 2013 | 10:17 AM
Wide Glide 25's Avatar
Wide Glide 25
I get between 39-42 on my wide glide with a stage 1 and a fuel pak. I assume this is normal or close to it. The bike runs good so I'm happy.
Old Apr 16, 2013 | 10:45 AM
dirtdobber's Avatar
dirtdobber
Riding style can either increase the mpg or lower it.
Old Apr 16, 2013 | 11:00 AM
jojo2dog's Avatar
jojo2dog
stage1 fuelpak average right now 41 but only on 2 tanks will see what happens down the road
Old Apr 16, 2013 | 11:38 AM
b2inUT's Avatar
b2inUT
My last long-ish ride I did I got closer to 45-47 MPG. Averaging around 42--I like to get on the throttle a little.
Old Apr 16, 2013 | 11:47 AM
WideGlideFever's Avatar
WideGlideFever
In town I average about 35 mpgs, I get on it pretty good all the way up till 4th gear. On the highway at a cruise I get 42-45 mpgs, I barely ever get on the highway though.
Old Apr 16, 2013 | 11:57 AM
Dynam1te's Avatar
Dynam1te
It has to do with your tune (and riding style) Most tuners add a certain percentage of extra fuel to compensate for the factory lean-ness and your additional mods. When I was running stock with pipes, I was getting around 42mpg. After the intake and tuner, closer to 35-38. This was because fuel was bumped up a few percent across my rpm range. This is probably whats going on with your bike.
Some of you getting over 40 even after a tuner, congrats! More fuel doesnt always make a bike run better, and you found the lucky sweet spot between performance and mpg!!
Old Apr 16, 2013 | 01:09 PM
PistolPete83
I concur. .
Old Apr 16, 2013 | 01:10 PM
PistolPete83
Cheers. .
