Removing tail light on 2012 street bob
Old Apr 18, 2013 | 09:39 AM
blueangel73's Avatar
blueangel73
I have a 2010 and the first thing I did was unplug the sparto light and remove it. The sig lights already run as tail/turn/stop lights and nothing changed. I pulled the wires running to the tail lamp and unplugged them from the harness. I built a new plug and wired it to run a light for my side mount plate. Later I removed the sigs and converted to LED strip and a side mount with a brake light (just added the thrird wire back to the plug I built.
To answer your question, you should be fine removing the tail lamp. Just unplug it and secure the wire, test all your lights and if they work as they did prior take it for a test ride (10 miles or so) if you have any issues they should show up, but I don't think you will. If all is good, remove the light.
This system is not like the systems on the super glide and other models where the sigs run via the fender light housing, so removing the tail lamp does not effect the side lights.
Old Apr 18, 2013 | 10:06 AM
rs87277's Avatar
rs87277
im selling my seat as soon as my custom le pera comes in, ill give you a good price. The seat is great, all real leather and nice but im just going for a diff look...
Old Apr 18, 2013 | 07:39 PM
Jimmy2Ball's Avatar
Jimmy2Ball
Thanks for the info. I ordered the side mount license plate bracket and will need to wire the light on this. Any thoughts on how to do this?
Old Apr 18, 2013 | 08:01 PM
blueangel73
I can't post my pic, but if you dig through my pics in my profile, you should be able to find a few diagrams I made up of how I have mine wired up.
Old Apr 18, 2013 | 08:12 PM
Jimmy2Ball's Avatar
Jimmy2Ball
Thanks I did see those and they looked pretty detailed. I will review and see if I can figure this out.
Old Apr 19, 2013 | 04:23 PM
Tomsprops's Avatar
Tomsprops
I hope you swap goes smoother than mine . I installed a Kuryakyn Panacea on my 2013 Streetbob .When I removed the STBob fender and went to a Superglide fender .
The Load Equalizer started to melt . Apparently the Paneacea isn't compatible on a 2013 with the Canbus style wiring ( Whatever The Phooey that is ) ? Or as The Demeaning ****** at Kuryakyns Tech center put it " It aint for that Bike Partner" .
Old Apr 19, 2013 | 06:58 PM
oldlefty's Avatar
oldlefty
this is exactly what i thought would happen. making new bikes harder to get aftermarket parts for. you will have to get stuff from HD until others make compatible components.
CAN bus
From Wikipedia, the free encyclopedia
CAN bus (for controller area network) is a vehicle bus standard designed to allow microcontrollers and devices to communicate with each other within a vehicle without a host computer.
CAN bus is a message-based protocol, designed specifically for automotive applications but now also used in other areas such as aerospace, industrial automation and medical equipment.
Development of CAN bus started originally in 1983 at Robert Bosch GmbH.[1] The protocol was officially released in 1986 at the Society of Automotive Engineers (SAE) congress in Detroit, Michigan. The first CAN controller chips, produced by Intel and Philips, came on the market in 1987. Bosch published the CAN 2.0 specification in 1991.
CAN bus is one of five protocols used in the OBD-II vehicle diagnostics standard. The OBD-II standard has been mandatory for all cars and light trucks sold in the United States since 1996, and the EOBD standard has been mandatory for all petrol vehicles sold in the European Union since 2001 and all diesel vehicles since 2004.[2]
Old Apr 19, 2013 | 11:22 PM
Tomsprops's Avatar
Tomsprops
Wow Look @ You ! Mr. Smarty Pants .
Old Apr 19, 2013 | 11:39 PM
oldlefty's Avatar
oldlefty
haha thanks but wikipedia is the smarty pants!
Old Mar 11, 2014 | 07:53 PM
ellsworth1984's Avatar
ellsworth1984
Stage I
Default Problems
So I un plugged my tail light on my 2012 street bob but my signals don't do brake light so I looked for a run brake turn module and no one makes on for a 2012 street bob that i can find any suggestions ?
