changed to a thunder header.. thoughts?
Old Apr 18, 2013 | 02:19 PM
RF_user21321's Avatar
RF_user21321
Default changed to a thunder header.. thoughts?
hey guys. I recently changed the pipe over to a thunder header pipe. I changed the exhaust gaskets to the HD tapered gaskets. I noticed I could only get about 3 turns on the 2 rear nuts. fired it up and it is sealed.... no leaks.
did U use the right gasket or should I have went with the flat style?
robin
Old Apr 18, 2013 | 02:36 PM
Romark's Avatar
Romark
I would check it again after a few heat cycles. I'm sure you will get another turn at least.
Old Apr 18, 2013 | 08:54 PM
vdop's Avatar
vdop
I've never had flat gaskets seal with a thunderheader, you used the right ones. Unless you modify the flange to work with the flat ones.
Old Apr 18, 2013 | 10:25 PM
target64's Avatar
target64
I have had 3 different exhaust systems on, all with screaming eagle flat performance gasket no leaks .
Old Apr 18, 2013 | 11:27 PM
RF_user21321
no mods.... just the tapered gasket.... just did not pull down like I thought it would... Ill retighten after a few heat cycles
Old Apr 19, 2013 | 01:20 AM
parts eeter's Avatar
parts eeter
My Thunderheader had the tapered gaskets on it when I removed it for maintainance. The dealer said I should be using the Screamin Eagle flat ones though?
1Cardiac
Exhaust System Topics
Aug 7, 2017 11:08 AM
emerican19
Feb 1, 2013 10:01 AM
TKanaley
May 29, 2012 12:29 PM
jm04
May 31, 2011 03:09 AM
RidemyEVO
Mar 9, 2010 10:02 AM
