what fuel programmer should i get? HELP
Old Apr 20, 2013 | 01:26 PM
duc_gnardleyson's Avatar
duc_gnardleyson
6th Gear
You forgot to say "in your humble opinion". The EJK tuner (Electronic Jet Kit) adjusts the fuel injection system the same way as adjusting & changing jets in a carburetor. In my humble opinion, that system is all that is necessary in order to rectify the lean problem inherent in the Harleys from the factory and exacerbated by a stage 1 upgrade. A dyno tune is a waste of money unless you are trying to shave tenths of seconds from your 1/4 mile time.
in my humble opinion that isnt 100% true. there is no way to get an efi motor or carb motor dialed in 100% by anything but a dyno tune in top gear. IT will change your timeing and volumetric effiency for the front and rear cylinder independently. maxing out the motors hp while making power in a nice rising fluid line with no flat spots. I struggled with all kinds of maps tuners programmers and nothing was even close to what a sert and dyno tune did for me before I had a built motor. the smooth power all the way to redline was matched by none. if you want a motor that runs at 80% or less than any software will work for you. if you want everything to run as smooth as possible with the most hp with no flat spots back fires pops or hiccups than dyno is the way to go. if you have a carb bike and think it runs great go get it dyno tuned and 99.9% of the time it will improve all around power and acceleration. not just for drag racing but coming out of a turn and rolling the throttle on and having power at any rpm!
Old Apr 20, 2013 | 01:45 PM
66cruiser's Avatar
66cruiser
Let me put it another way. I don't need or want to spend the money necessary to dial in my motor 100%. My bike runs better than it did stock, better than it did with a stage 1 download from the dealer & better than most of the bikes ridden by folks I know who are not using a tuner. The average rider doesn't need a dyno tune any more than the average motorist needs a dyno tune on his car.
Old Apr 20, 2013 | 02:56 PM
duc_gnardleyson
6th Gear
so when did this become about you? and what you want? now this is about what you want and not about info for harbourside to make a better choice of tune or program. the intial cost is more but benifits are worth every penny even if your an "average rider". you are correct though if you consider an "average rider" being a rider that doesnt rev his or her bike over half throttle.
Old Apr 20, 2013 | 03:13 PM
66cruiser's Avatar
66cruiser
Again, in your humble opinion. To quote the OP "i am leaning towards the fuel programmer becuase its cheaper and my bike isnt set up as a high performance ride etc etc. and i dunno if i will keep it much longer after this season.. thinkin of different rides already haha. anyways... my question to you experienced folk is.. Which programmer should i get."
Your advice is to spend way more money than necessary in order to solve the OP's problem which "right now on decel its popping and what not." A problem which is easily solved with a total investment of under $200. BTW the 6 adjustments on the EJK cover throttle positions from idle to WOT. I'm not sure you know what you're talking about here.
Old Apr 20, 2013 | 03:58 PM
duc_gnardleyson
6th Gear
im obviously wasting my time trying to share my knowledge. I understand your device covers idle to wot. what im saying has nothing to do with that. When you get your bike dyno tuned youll understand what im talking about. lets see your bikes power curve look like that with your current setup
Old Apr 20, 2013 | 04:03 PM
Qdog002's Avatar
Qdog002
DUC you are not wasting your time. 66 is just pointing out what the OP wants. Very simple answer to a simple question from the OP.
Old Apr 20, 2013 | 04:42 PM
Uncle Chester's Avatar
Uncle Chester
Originally Posted by Broken Wing
It's 8 years old & yer' prolly gonna sell or trade it in. Why drop hundreds into something that's on it's way out and can't be R&R'd onto the new bike? I say wait & spend the money on the new 103 motor.
If the decel-pop is killin ya, Try the VIEDs or OIEDs. They do work & they're dirt cheap compared to an ECU upgrade. (Not sure why Uncle Chester said they won't work on the '06.)
I agree with the earlier Fuelmoto reviews. Buy from them when you do buy.
You're right. I just had a major brain fart when I wrote that. I forget sometimes that dynas got O2 sensors before the other bikes.
Old Apr 22, 2013 | 12:09 AM
Broken Wing's Avatar
Broken Wing
No sweat. I get those senior moments too.
(I'm pretty sure they're caused by wimmens'.)
Old May 22, 2013 | 01:52 PM
wendon65's Avatar
wendon65
OK Now.
Can we make this about me for 1 minute? I am with 66 Cruiser about how much money and time I would like to spend. I just put on a pair of MGS True duals on my 2012 bagger. I have ridden it for a week and now have the cash to upgrade the intake to a SE air kit. With that I believe that we all agree that a tuner kit is necessary. #1 I would like to do this myself.
#2 I want the bike to run good. I am not looking to race it. I have limited knowlege about tuning so I also want something I can understand.
Old May 22, 2013 | 03:58 PM
socialoutcast's Avatar
socialoutcast
I would say this about tuning. It depends on what you are looking for out of your bike. Most piggy back type tuners will not take timing and other major things into consideration when screwing with your map. The only TRUE way to do this is having direct access to the fuel, timing, VE, and other tables required to make a smooth running bike. Having said this I have used the V&H fuel pack (Its crap) I have also used the DynoJet PCIII USB (Not bad but not great). Neither of these remapped all tables in the ECM. To do this you have a few choices. You can get a PV, Zippers Thunder Max with Auto Tune, SE Race Tuner. These are the 3 I hear about the most. On my last bike I had SEII slip ons, and a AN Big Sucker 2. Using the piggy backs my motor ran hotter and just did not perform at all as I wanted. This is far more noticeable on long rides. My 2 cents is you have a 10k+ bike with $100s in parts so why would you go cheap on the 1 part that runs it all and can potentially turn your bike from a 10k Harley to a $100 crap motor?
A few sayings I have heard and live by are:
Fast, Reliable, Cheap. = Pick 2 and ONLY 2.
You can put the best parts on your bike but if you are running it through **** its always going to be ****.
Having said that call Fuel Moto they will get u square with exactly what you are looking for at a good price.
