Brake line ?
Old Feb 20, 2007 | 08:31 PM
phreak's Avatar
phreak
Default RE: Brake line ?
The problem is my bike is in many pieces. I took everything apart before looking in the book for cables. I though I'd find all the cables listed as stock and then just ones that were about 6" longer. As it turns out JP cycles doesn't list all the cables for a FXDBI. Wide Glide cables should be the same as the Bob Right?
I thought the WG bars were 12s? Don't know. The bob bars are 10-10.5
+6 Will work up to 16" apes, I guarantee. So would a 52" brakeline.
Old Feb 20, 2007 | 08:32 PM
phreak's Avatar
phreak
ORIGINAL: Whiffleboy
ORIGINAL: phreak
Best bet is to take a piece of twine, and route it phrom the caliper up to the master cylinder, then cut or mark the twine, and lay it out over a tape measure.
Or you could just route your wife's fabric tape measure and be done with it. :-)
Whiff
I wish my wife had one. Hell I wish my wife knew which end of a needle to put the thread through.
Old Feb 20, 2007 | 09:25 PM
phreak's Avatar
phreak
ORIGINAL: HOGRIDA_06
Whaddayaknow!
Just came home to a new J&P catalog
pg. 739 - Goodridge Ebony Series brake Lines & phittings
pn# 241-759 is a 52" BLACK brake line
pn# 241-762 is a 12mm straight BLACK banjo phitting
pn# 241-763 is a 10mm 35* BLACK banjo phitting.
Did you phind your clutch & throttle/idle cables yet?
pg. 864 - Barnett Clutch cable
pn#520-945 BLACK vinyl +6 clutch cable
pg. 862 - Barnett throttle cable
pn#520-909 is a BLACK vinyl +6 throttle cable
pn#520-924 is a BLACK vinyl +6 idle cable phor a FXDLI. I called J&P and I think they had a different pn# specifically phor an FXDBI
Old Feb 20, 2007 | 11:24 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Phreak, as I'v said before you rock. Thanks for all your research. One of these days I'll have to buy you beer.
Old Feb 21, 2007 | 12:46 AM
phreak's Avatar
phreak
No problem man. Those are the same parts I bought phor myself. I knew what I was looking phor so it made it easy.
grancuda
Feb 28, 2016 08:42 AM
Kev_England
Oct 27, 2010 02:33 PM
buggn031
Apr 29, 2009 12:19 PM
Biker Trash
Oct 28, 2008 09:23 AM
motordrum
May 2, 2008 01:25 PM
