Tools needed to replace spring-loaded cam chain tensioners (06-down style)
So what if I got the hang of it, and started changing other people's tensioners? Or changing other people's pushrods and cams? That would justify having to buy the tools then...right?
I do them for other people but made my own tools. If I did them every day I might get the tools but I prefer to make them as I am tight with my money as prefer to spend it on Tequila and Gas
You MADE your own tools? That's pretty cool. There's a couple shops here that could make the pieces given that I explain form and function to them first. I could try that too. Thanks for the idea!
If you have a grinder, cut off wheels and a small welding machine or a friend with 1...Voila...Like the gear locking tool that goes between the 2 cam gears... You can take 2 part epoxy and put it in a Ziploc/plastic bag, let it set up and take your gears off, then cut it where it would be flus with the back of the gears so you can re-use them... it will look like the factory tool....If i had to change the bearings in the cam plate i might use my indy for that...
There you go..... FREAKING PRIORITIES...lol... A man has to have these little luxuries...
I just changed tensioners and cams on my 2000 Wideglide. No special tools needed.
I unloaded the tensioners with a pair of slip joint pliers with a shop rag around the jaws and piece of coat hanger to lock them in place.
Stick entire cam plate in oven and heat it for about 30 minutes at 300 deg and the cams will just fall out along with the bearings.
Used the Cyco tensioner pads which cost about $20 and then put everything back together. Again, camplate in oven then drop the cams in with bearings.
Check out Harleyhogs layer site and he has a great how to on this removal.
When putting the sprockets on without the chain to check for level I just used one of those rubber strap wrenches to hold the cam sprocket while tightening the bolt.
Stick entire cam plate in over and heat it for about 30 minutes at 300 deg and the cams will just fall out along with the bearings.
Another good tip/idea...Necessity is the mother of all inventions...
They don't look like tools, they look like broken tools and scraps of metal....but they work!!
