Starting Problems
Old May 2, 2013 | 08:54 PM
nevil's Avatar
nevil
Originally Posted by Skastle
The battery seems to be fine.
How can you tell without having it tested?
Old May 2, 2013 | 09:41 PM
Jackie Paper's Avatar
Jackie Paper
Doing post 8 is free. The compensator is $200-$400. Take your choice. These bikes are quite reliable. Usually it's the simple things. I have even seen people have trouble because they simply do not hold the starter button down till they are running. But just offering my opinion. Good luck.
Old May 2, 2013 | 11:12 PM
Skastle's Avatar
Skastle
2nd Gear
I took it down to autozone and had it check
Old May 2, 2013 | 11:13 PM
Skastle's Avatar
Skastle
2nd Gear
I'll keep messing around with it, I appreciate your help!
Old May 3, 2013 | 12:42 PM
bobnehoc's Avatar
bobnehoc
My 07 LR does this after it is hot. Say I stop for gas and when I go to start her up she grinds and sometimes it takes several tries to get the starter to catch. Problem is the starter clutch is bad. I will be changing mine to an All ***** Starter Clutch. They are around $80 and I have heard but have no proof that they are better than the HD ones.
Old May 3, 2013 | 07:57 PM
IMKMA's Avatar
IMKMA
I have this problem sometimes and it seems to be flooding. I have found out that when I restart the bike when it is hot if I turn on the ignition switch and immediately hit the start switch it starts no problem. If I wait for the fuel pump to stop and the light to go out I have the problem you describe. Hope this helps...
Old May 4, 2013 | 06:07 AM
DJY's Avatar
DJY
OP, mine did the exact samething, til I changed the compensator. Just sayin.
Bubba Zanetti
Jul 13, 2019 02:58 PM
TravisD27
Apr 9, 2018 02:05 PM
JLey
Engine Mechanical Topics
14
Jun 16, 2015 05:26 AM
StephenBooth01
Shovelhead
27
Jan 30, 2015 09:34 AM
typennies79
Mar 27, 2014 08:23 AM
