Dyna Wide Glide Air Filter Cover Question
I was hoping that someone might be able to help regarding my air filter. I just got my bike Master Tuned and had Vance and Hines Big Shots staggered placed on as a new exhaust system. While I like the stock air filter cover, I do like the exposed filter look. Unfortunately, the place I got the work done at gave me a new filter with the same look/shape and I have had a hard time finding a new cover. Currently I have the attached filter, and would like to get a chrome cover like the one shown in the pic. Only problem I have seen is, I haven't found this as a sole purchasable item, I would have too buy the entire kit. Any suggestions of where to look or is this something that is even available?
http://www.knfilters.com/search/prod...x?prod=HD-0808
http://www.knfilters.com/search/prod...x?prod=RK-3932
I appreciate any help you can provide!
Thanks - Tim
Sell the new filter and purchase a new cleaner kit.
Be happy with what you got.
The cover you posted will not work on your air cleaner assembly. They have different cover mounts.
You can order monday by calling 1-800-858-3333
This info is if your filter is a rk-3932...was kinda hard to tell which one you had by your post
The aftermarket kit uses a two screw system to mount the aftermarket cover. The replacement filter doesn't appear to have these screw holes. These are just observations from the OP's links.
