Need help . . Fuel gauge pegged on empty
Old May 10, 2013 | 02:49 PM
CobraEd's Avatar
CobraEd
Default Need help . . Fuel gauge pegged on empty
I am hoping to get some insight and answers on my problem. Here goes:
I have an 07 Superglide. Last time I rode it a few weeks ago, everything was fine. Started it up today and found the fuel gauge pegged below empty and the low fuel light was on. The bike seemed to run fine, everything else worked so I figured maybe just a stuck float on the sending unit. I went for a ride and it stalled once and then when I stopped to visit a friend, it would not start. No electric at all anywhere. I discovered that a battery connection was loose because I am over careful tightening the cables into soft lead threads. So, I tightened it up and the bike started right up and ran great. BUT, . . . the gauge is still pegged below empty and the low fuel light is still on. The tank is full
What do you all think. Does the gauge need time to re-set itself after the flakey battery connection or is there truly a separate fuel gauge/light problem?
Any thoughts are appreciated
Ed
Old May 10, 2013 | 03:02 PM
ynots's Avatar
ynots
your fuel gauge problem is a separate issue
Old May 10, 2013 | 03:05 PM
Jackie Paper's Avatar
Jackie Paper
Possible low voltage took out a fuse? Power is coming from the ignition switch for gage. Make sure plug connections are good at ignition switch, wire going into the tank and the led indicator light connection.
Old May 10, 2013 | 03:10 PM
checkers's Avatar
checkers
Ed
Clean and tighten your battery cables, not just a "tug" test: remove them and clean and retighten. Post back after that
Old May 10, 2013 | 04:44 PM
CobraEd's Avatar
CobraEd
Default Fixed it !
Well first I went back and made sure that the battery connections were really tight. They were but the gauge stayed on empty. Then I suspected the chrome Kuriyakin neck cover I put on about a year ago. I remembered that it pressed really hard on the wires where they all come out of the hole in the neck. Sure enough that was it. It was squeezing the crap out of the wires and had pinched/shorted them out. I bent the chrome neck cover so that there is no more pressure and all is well in Harley Land again
Ed
Old May 10, 2013 | 05:31 PM
rooti's Avatar
rooti
Glad you figured it out and kept the cash in your wallet. I love free fixes
Old May 11, 2013 | 07:40 AM
checkers's Avatar
checkers
Ed
Good to update the post.
Old May 11, 2013 | 08:02 AM
Account Retired's Avatar
Account Retired
Old May 11, 2013 | 08:06 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Sometimes we can be our own worst enemy when we do these mods. Glad you figured it out and posted back.
supermanotorious
Jan 26, 2019 08:00 PM
Jerry In Maine
Feb 23, 2015 02:32 PM
VTmonster
Electrical/Lighting/Alarm
Aug 2, 2014 12:07 PM
chopper king matt
Dec 4, 2012 01:30 PM
k23rd
Jun 1, 2005 04:15 PM
