Dyna Shocks
Old May 10, 2013 | 08:07 PM
1smcvo's Avatar
1smcvo
Default Dyna Shocks
2013 dyna....Progressive 970 Piggybacks Vs. Works Performance custom shocks, any thoughts?
Old May 10, 2013 | 08:17 PM
Ridewva's Avatar
Ridewva
I can't comment on Progressive's but I just replaced my stock shocks on my FXDXI with Works 13.5" Steel Trackers. I took my time mounting them making sure they moved freely w/o binding. They are a definite improvement. Mention you're a HOG member and get a 10% discount.
Old May 10, 2013 | 08:30 PM
HYPR's Avatar
HYPR
Can't comment on either but today after waiting anxiously since 4/13/13 my new Ricor shocks showed up. I installed them and set the SAG at 1.75" solo without any riding gear on and with the Bags off (I am guessing I will loose about .25"-.375" with all the k-rap). The instructions call for between .75"-2.0". They explain that as you get closer to the .75" # the improve the bottom out resistance at the expense of comfort and stability. They go on to say as you get closer to the 2" # you improve the comfort at the expense of the bottom out resistance. In addition they indicated as you increase the load as in adding a passenger this will decrease the SAG. The nice thing about the Ricors is the adjustment is easily done by hand so this can be fine tuned while on the road.
I took the bike out for a fairly spirited ride over some rough and twisty roads and I am supper impressed. It feels like a completely different bike so needless to say I would recommend you consider them.
Bob
Old May 10, 2013 | 09:04 PM
rooti's Avatar
rooti
I second the ricors
Old May 10, 2013 | 10:04 PM
Puffdaddy's Avatar
Puffdaddy
I would lean toward any shock that can be ordered for your weight and riding style. I'm sure the Progressives are good shocks, but they are "one size fits all". A properly weighted spring for your weight allows you to get in the middle of the stroke to avoid bottoming or topping out.
Coming from sport bikes, I know the importance of rebound damping (prevents the shocks extending too quickly). A couple clicks make it softer or sportier.
Research it long and hard and it will be the best upgrade you can do to your bike (IMHO)
I have Ohlins, and couldn't be happier. I did look at those you mentioned...
Old May 11, 2013 | 12:26 AM
Crazy's Avatar
Crazy
Bob
Did you get cruiser, sport, or super sport?
Old May 11, 2013 | 12:37 AM
cnntnsxty's Avatar
cnntnsxty
6th Gear
I have Progressives on an 03 Dyna. I like them but definetly have to adjust between 2 up and solo (which I always remember to do right after crossing the RR tracks 2 up) still better than stock
Old May 11, 2013 | 01:52 AM
ynots's Avatar
ynots
My 970's are set at 1 1/4" sag w/me & ol. The only thing I change for solo is lighten the compression dampening about 5 clicks. I smile every time I pass over a R/R crossing.
Old May 11, 2013 | 06:25 AM
stilup's Avatar
stilup
+1 on the Works streettrackers.
Cost less with great control and comfort.
Rebuildable for a fraction of the cost of new.
Old May 11, 2013 | 06:33 AM
Ridewva's Avatar
Ridewva
Originally Posted by Puffdaddy
I would lean toward any shock that can be ordered for your weight and riding style.....
Very true, Works does this and are rebuildable.
