2 cylinders, 2 different AFR's
Old May 12, 2013 | 04:55 PM
DJY's Avatar
DJY
Default 2 cylinders, 2 different AFR's
Why? Thanks for your answers.
Old May 12, 2013 | 05:27 PM
atrox88's Avatar
atrox88
You might try asking that question here. There has been a lot of talk about AFR's and tuning at this link:
https://www.hdforums.com/forum/elect...on-thread.html
Old May 12, 2013 | 06:41 PM
stilup's Avatar
stilup
I believe it's different cylinder angles and the rear runs hotter.
Old May 13, 2013 | 01:38 AM
Foxster's Avatar
Foxster
Depends how much difference you are reading.
There is a difference between the two cylinders, was also on the carb bikes but you had little control over it.
Generally the rear cylinder runs a little richer to keep it cooler as the air flow to it is less.
If you have a large difference between the cylinders then it might be worth looking for a fault like the inlet seal, spark plug, etc.
Old May 13, 2013 | 07:42 AM
maddghost's Avatar
maddghost
Temperature at the rear cyl is higher, main reason being that it is hidden by the front cyl. And maybe, don't quote me on this, but the rear cyl fires a split second later than the front.
Old May 13, 2013 | 08:02 AM
Tired's Avatar
Tired
You have two separate AFR tables? You're good! Which tuner are you using?
Old May 13, 2013 | 08:40 AM
DJY's Avatar
DJY
Micro Tuner
Old May 13, 2013 | 09:24 AM
rubberfrog's Avatar
rubberfrog
Lot of tuners give you this info.
Old May 13, 2013 | 09:38 AM
Tired's Avatar
Tired
Originally Posted by DJY
Micro Tuner
Interesting. Thank you.
Old May 13, 2013 | 10:29 AM
Foxster's Avatar
Foxster
You can do this with most programming tuners (TTS, SEPST, etc). Its just that its usually done with one AFR table and then the difference in fueling is adjusted in the cylinder-specific VE tables.
This is one of the nice differences between carb and EFI, of course. With a carb you throw the fuel in the manifold and it, hopefully, gets split evenly between the cylinders. With sequential port fuel injection, each cylinder has its own injectors near the intake valves.
enjoytheride79
Dec 19, 2018 09:32 PM
Rickierockit92
Shovelhead
Jun 5, 2018 08:27 PM
GoPro Steevo
Feb 24, 2011 10:35 AM
mulch63
Exhaust System Topics
May 3, 2007 02:17 PM
83ironhead
Aug 29, 2005 12:02 AM
