Stripped A/C bolt....am I screwed ?
Old May 15, 2013 | 08:08 AM
1HD1C's Avatar
1HD1C
Originally Posted by DM1975
Nope, it's broke for good. Let me know where to come to pick it up and I'll dispose of the motorcycle for you
Vice grips super tight and twist. If you can't use that then an easy out may work. Also, you mayb be able to tap a smaller 12 point socket onto the bolt with a hammer.
i was going to suggest nearly the same thing, a lot of times when you strip it out like this you can move to a metric socket and tap it on and then remove it..
Old May 15, 2013 | 08:30 AM
WG2011's Avatar
WG2011
I agree vice grips have always been my go to in this tyoe of situation. Dig into the head of the bolt tightly with them and turn as you would with a wrench.
Old May 15, 2013 | 08:34 AM
lionsm13's Avatar
lionsm13
One of these(hand held impact driver) units will loosen the bolt provided you can still have enough real estate for a bit to get on
You turn and whack it on the end w/a hammer while you are attempting to turn it in the direction you want it to go or loosen as is the case.
user 46092
Exhaust System Topics
Aug 22, 2013 06:28 AM
rojuwi
Oct 26, 2012 10:53 AM
CD3
Wheels/Tires
Jul 19, 2012 12:40 AM
Big Sled
Apr 25, 2008 07:19 PM
06Heritage
Mar 15, 2006 09:34 PM
