wiring harness ??
Old May 16, 2013 | 04:35 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by JRK5892
man such great info in this thread for people working with these plugs... they can be a pain in the *** if you are not doing them right... great info Mud and Rene
Isn't that why we spend so much time in here, Joe?
Old May 17, 2013 | 10:07 AM
teedub79's Avatar
teedub79
I figured it out! so as I was saying I'm installing new ape hangers so I got all new wiring and cables. as far as the wiring from the control housing once you disconnect the harness that runs inside the frame..from there you need to seperate the harness with a small flat head screw driver (the harness you plan on extending) on one side you have the white locking device remove it completely on the other side you have a rubber piece slide it back and the wires will be exposed, inside there are tiny clips that you need to push up on as you pull the wire out at the same time...just like everyone else said make sure you draw a diagram so you know where to put them back ...if you didnt do that you can always look on the female harness it conects to thats still inside the frame and match the colors up to that....09 fxdc
pp6000v2
Mar 1, 2015 04:44 PM
D1gger
EVO
Jun 30, 2013 09:47 PM
teedub79
Dyna Glide Pictures
May 16, 2013 12:19 PM
putergod
Mar 13, 2011 04:59 PM
lunning
Feb 7, 2009 12:50 AM
