wiring harness ??
there is a white locking device does it just slide up or need to be removed all the way?
Edit: collecting the info below I didn't notice you posted too, Tom!
Wiring
...........mud
............................amp connectors
https://www.hdforums.com/forum/4277699-post1092.html *
............................amp connectors - Video Part 1
............................amp connectors - Video Part 2
............................deutsch connectors
https://www.hdforums.com/forum/4277701-post1093.html *
........................................deutsch source
............ .............. ................... http://www.deutschconnector.com/
............................molex connectors
https://www.hdforums.com/forum/4277695-post1091.html *
............................taillight wiring diagram
https://www.hdforums.com/forum/4277707-post1094.html *
............................extend wiring
https://www.hdforums.com/forum/dyna-...-controls.html
............................access wiring
https://www.hdforums.com/forum/4350331-post9.html *
............................armored under fender wiring
https://www.hdforums.com/forum/2549879-post103.html
............................soldering
https://www.hdforums.com/forum/dyna-...ring-tips.html
...........pontiac69
...........................accessory wiring
https://www.hdforums.com/forum/dyna-...seat-info.html
Rene, I am suspecting - Molex.
in which case - answer to original ? would be - slide it up.
it's always nice to have a bit more info in the original posting...............
Console gauges/indicator lamps (all except FXDC, FXDF) 12-place Deutsch Inside top frame tube
Indicator lamps 8-place Mini-Deutsch (FXDC, FXDF) 10-place Mini-Deutsch
(FXDB) Under fuel tank console
Right Hand Controls 6-place Molex Inside top frame tube
Left Hand Controls and Horn 8-place Molex Inside top frame tube
Front Turn Signals (left) 3-place Multilock Inside top frame tube
Front Turn Signals (right) 3-place Multilock Inside top frame tube
Ignition Switch 3-place Delphi Inside top frame tube (FXD, FXDL) Under fuel tank console (FXDC, FXDF)
Headlamp 4-place Multilock Inside top frame tube
Speedometer 12-place Packard Back of speedometer
