Fi2000 POWRPRO
"This is my favorite tuner, just plug it in and your done! No Dyno, no Computers!"
Fi2000 POWRPRO WITH CVT TECHNOLOGY.....POPS PICK
Continuously Variable Tuning (CVT) is the key to the remarkable performance the Fi2000 PowrPro delivers
PowrPro uses electronic control technology that calculates the bikes rate of acceleration by reading crankshaft rotation at the flywheel and
changes in load just as a dynamometer measures acceleration at the rear wheel
PowrPro measures and adjusts fuel flow during acceleration to the injectors in microseconds for super-fast fuel tuning continuously and
automatically; net result: precise EFI tuning now happens in the real world in real time, nonstop, up to 80 times per second
New patented technology unlike any other system on the market
PowrPro tunes to precise air-fuel mixture to create maximum power 80 times per second (does not tune to a predetermined arbitrary AFR)
Creates that adjustment to maximum power on every squirt of the injector
Its like having the best custom map writing, dyno operator tuning your fuel every time you crank the throttle
Tunes every gear, every roll on, every environmental change, every engine mod, lugging the engine, winding it out to redline: it reacts, verifies
and adjusts when the bike is accelerating
Provides perfect acceleration fuel settings in any condition, with any exhaust system with any engine modifications
No matter what kind of new hardware you install on your bike a new exhaust system, a freer-flowing air filter setup or even a big-bore hop-up
kit with high-performance cams PowrPro continues to analyze and tune your engine for peak performance
No external adjustments needed
No dyno needed
No additional components needed
Here is a you tube video from JCMotors
delivers a great boost to a stage 1 setup.
it gets better and better.
I think the bottom line was that some people got lucky and it worked OK out of the box, some had to return it once or twice to get one that suited their bike and some never got it to work well.
Personally I think its over-hyped. It won't be a substitute for a proper tuner and, because it has no computer interface, if it doesn't work just right then you have no option but to return it. I think you would be better saving a bunch of change and just fit some Xieds.
