tman 590 cams in a dyna?
Old May 31, 2013 | 05:42 PM
dirtdobber's Avatar
dirtdobber
I am using V&H 2 into 2 big radius.
You can feel when the cam hits, it is very obvious.
90 Tq.. at 2,500 rpm's
Old Jun 1, 2013 | 10:13 AM
parts eeter's Avatar
parts eeter
Originally Posted by 07bobber
The 106 is a big bore I got from revolution cycles, bored out cylinders with flat top Kb pistons, stock bottom end. I ride like an ******* most of the time. Wink was suggesting the s&s 585 but I wanted the compression releases also since the springs will accept a high lift. Therefore gave me more option later if I decided to change cams again in the future.
S&S 585 Easy Start Cams, That way you dont need compression releases in the heads...
Have you considered this?
Old Jun 1, 2013 | 10:22 AM
07bobber's Avatar
07bobber
yeah, wink was pushing the easy start cams so I didn't have to do compression releases but I don't want to be stuck at only s&s cams if I change in the future. so I had him add them in the headwork
Old Jun 1, 2013 | 10:40 AM
parts eeter
Just have him prep for the compression releases and run plugs in them. Then you can just remove the plugs and install comp releases later if u need them. Besides, if the 585 cams arent what you end up wanting, they make several options in the EZ start design.
Old Jun 1, 2013 | 10:55 AM
parts eeter
Cams are kinda funny, cuz everyone has a opinion and preference, but for me I dont get hung up on all the hype. I just pick a popular choice cam, in the RPM range I run for the given displacement of my build. I have never had any regrets in choosing this way.
This method has been working for me for the last 20 years, prior to that I mostly rode 2 stroke MX bikes.
Old Jun 1, 2013 | 12:03 PM
07bobber's Avatar
07bobber
I might just stick to my tw6 for now unless I sell them, I can't really afford to get another set of cams
Old Jun 1, 2013 | 01:16 PM
NC-WG2011's Avatar
NC-WG2011
I have a 107" with SE 211 cams at 10.5-1 compression. They're not a high lift cam at all but work really well with higher compression. Dyno in 2 weeks but they definitely have lots of torque in the mid and upper range
Old Jun 1, 2013 | 03:22 PM
Spud17's Avatar
Spud17
Here is my dyno sheet with the woods 8-6 cams. I have a 103 with head work and high comp. pistons and a 2 into 1 exhaust with stock throttle body. So I'm guessing with your build your numbers would be better.
Old Jun 11, 2013 | 08:28 PM
mud's Avatar
mud
I can't afford a top 1200 dollar race port and polish.
1200 bux for head work??
Old Jun 11, 2013 | 11:02 PM
07bobber's Avatar
07bobber
Yep that's the price tag I was told by 4 different big name shops
I ended up going to wink eller for the headwork.
They are done and ready for pick up tomorrow.
