I have the Sputhe, It was worth it to me. More stability in corners and wind. The difference is noticeable. I think they are pretty much the same thing, Tru Trak is bulkier looking and Aluminum, The Sputhe is steele So it is thinner. I think that's the main difference.
I don't have either. I have heard mostly good things about both, although there are also stories of increased vibration after installing stabilizers.
I went a different route; Avon tires, Ohlins suspension (front and rear) and a steering damper. I haven't had a tank slapper, but regardless of what I do to the bike, do to it's design, it will never feel as solid as my Ducati Diavel at high speeds.
Good luck with your build.
Originally Posted by jakespade
What about Daytechs swing arm kit? Would that keep my *** in check?
Like I said, this thing is gonna scream and I don't need to worry about tank slapping at 140+
The True Track is not some sort of snake oil. If you study the reasons why stabilizers are helpful to engine mounted swingarm motorcycles you will understand the physics involved. Before I installed True Track I consistently had rear wheel wobble when cornering hard, after installing not a single wobble. True Track or Sputhe - both will work, you choose.
Precisely what they are designed for. When pushed hard especially on an increasing radius curve the torque applied will cause the bike to rear steer and these devices fix that.
Now about straight line consistent speed wobbles, those generally are attributed to a variety of other issues, motor mounting defects being only one of them.
Deceleration and acceleration wobbles can be a number on issues including but not limited to wheel bearings, head bearings, alignment, tire defects, suspension, amongst other problems. These devices can't hurt but they aren't the universal cure all for every handling issue.
Personally I have the True Track and am very pleased with it.
Bob
Have a True Track on my Switchback. It's the single best mod I've done. I spend almost all my time on back roads and it's made the handling tighter. Kurt
Thanks guys. I'm going to get a set of spherical bearings to replace the rubber bushings on the swing arm and try out the sputhe. The more I look, the less bulky the sputhe seems.
After I get the control done, I'm hopping up this bike.
Thanks again guys.
Post the specifics of these parts. Pics would be great! I think if you did this, checked steering bearing fallaway, motor mounts, good shocks,installed some Avon Venom tires or Metz 880 tires the bike would be solid. It will always get better with a True Track or Sputhe from there but you may not find a need for it after these fixes.
