oh i replaced them just before the build because of a fuel pump issue the contacts got corroded as alll hell
for the life of me i a=can not figure this out.... i just went and checked the quick connect and pulled the relays and put the spares in
i go have two rndom connections i noticed that have no connectors anywhere they look the same and i seen somewhere about california emmission sensors but i think i have the intake wired up i just checked again
Check your grounds, clean/tighten your battery cable terminals, pull your main blade fuse for a few minutes (big huge fuse) and let your system reset and try to start it again. That may help but not sure.
one more thing i may have gotten slightly drunk out of frustration and i cant remember which which goes to which injector now one is yellow one is black... (yeah i may have gotten slightly stressed drunk at the time)
but ill pull the fuses and relays tomorrow moringing and try agauin
After you turn on your ignition and the fuel pump primes, pinch the fuel line with your fingers.
If the fuel line is hard, it has pressure, but if it collapses easy, you don't have fuel pressure.
