Leak question...
Old Aug 21, 2005 | 06:14 PM
kulreign50's Avatar
kulreign50
Default Leak question...
Did a 150 mile ride today and noticed a small amount of fluid near the area where you would check the chain tension on the outer primary. It appeared fairly clear in color and was a small amout. It had an oil like consistantcy. My question is that area is held together by several allen bolts, is there a gasket behind there that may need replacing? Thanks for your input.
Old Aug 21, 2005 | 07:01 PM
HDF Tech's Avatar
HDF Tech
Default RE: Leak question...
If it is the primary inspection cover you refer to, yes there is a gasket in there. You should follow the torque settings closely as you can warp the cover real easy over tightening it and cause an even bigger leak. Check the cover with a straight edge if you remove it to see if it is warped.
Old Aug 21, 2005 | 09:30 PM
kulreign50's Avatar
kulreign50
OK thanks for the advice and prompt response. Stay safe!
Old Aug 24, 2005 | 10:31 PM
kulreign50's Avatar
kulreign50
Default RE: Leak question...UPDATE>>>
Went to the dealer today and just like you said, primary inspection cover was warped. They replaced it for free. I could hardly believe it. Although they did crack me for $500 a month back to replace all of the gaskets and o-ring. Well thats it for now thanks again for the help.
[IMG]local://upfiles/3057/21160445DF69491A9D2DC11BB9C92F26.jpg[/IMG]
Old Aug 26, 2005 | 10:09 AM
HDF Tech's Avatar
HDF Tech
Glad it worked out for you.
Tralfaz
Jul 31, 2022 04:50 AM
dproto09
Jan 19, 2017 10:07 AM
Gray_Drifter
May 15, 2011 09:37 AM
dFREDb
Sep 1, 2010 10:07 AM
WildBill_50
Jan 14, 2009 07:19 PM
