front exhaust valve npise
Old Jun 17, 2013 | 06:02 PM
Notz's Avatar
Notz
Default front exhaust valve npise
OK y'all I just built my engine (see sign for what I did) I have been having a loud loud clacking on the front of the rocker box on front jug.... today I pulled the covers and did and oil change and while in there shaved the spots it's looked as if I may have been touching the covers... I slapped it back together and it is still loud.... I am totally lost on what it might be any help is apreciated
Old Jun 17, 2013 | 08:05 PM
Robtarra39's Avatar
Robtarra39
Could be a tired litfer, does it have adjustable push rods, if so they may need adjustments. My friends bike had a loud tick and after adjusting the push rod it went it away
Old Jun 17, 2013 | 08:41 PM
Notz's Avatar
Notz
I used the stock rods lifters ect ect I went with the 585 just because it was able to work with some stock parts. I die grinded the spots that looked like the rockers might have been touching. And it seems to only be on the front jug exhaust rear is silent
Old Jun 17, 2013 | 10:25 PM
Notz's Avatar
Notz
ok update i just drove home fromw ork and it seems that the clicking noise is only there while under acceleration.... any ideas?
Old Jun 17, 2013 | 11:35 PM
Notz's Avatar
Notz
Does pinging cause valve noise? I'm wondering if maybe my spark advance is too high with the canned map I used as a base? But I would think a canned map would cause the rear jug to make the same noise. And it doesn't, it only makes it's under acceleration and idle.... No noise on deaccel
Old Jun 19, 2013 | 08:42 AM
Notz's Avatar
Notz
SOLVED! i had an exhaust that wasnt seated or my lower rocker box gasket is not seated right but i have a small exhaust leak coming from the front jug at the rockerbox/exhaust level noise has been found
ShaZAM
Mar 27, 2016 03:13 PM
SURFOR Chop
Exhaust System Topics
Nov 10, 2010 02:08 PM
SDVmnt
Jul 2, 2010 10:19 PM
tree88
Aug 6, 2008 11:46 PM
05HARLEYMAN
Sep 27, 2007 07:39 PM
