remap when changing pipes?
Old Jun 26, 2013 | 03:54 PM
jgcable's Avatar
jgcable
Default remap when changing pipes?
Would I have to have my fuel injected 2006 Wide Glide remapped if I changed from a Rinehart 2 into 1 exhaust to a Vance & Hines Short Shot exhaust?
I don't know if my bike has race tuner because I bought it from the dealership used and they didn't tell me. It doesn't have power commander. I looked.
Thanks..
Old Jun 26, 2013 | 05:22 PM
Antonio Balls's Avatar
Antonio Balls
Default Just Wondering
Why would you switch from a 2:1 to a true dual?
Old Jun 26, 2013 | 05:39 PM
Dynam1te's Avatar
Dynam1te
^ exactly.
Old Jun 27, 2013 | 12:35 AM
loopie's Avatar
loopie
probally not buddy, it all depends if the previous actually changed the map/after market computer.. Personally put your new pipes on and install some new plugs, do some miles say 2 tanks then look at your plugs for colour,,, chances are you will be sweet too go. The only other way is too use a dyno too verify thru the rev range your mixture values are correct..If not then they can change your fuel map/computer..
Old Jun 27, 2013 | 07:31 AM
jgcable's Avatar
jgcable
I have a Rinehart 2 into 1 and it has a 4.5" diameter muffler. Because of this massive size it hits the bottom of my newly purchased Boss Bags saddlebag.
I was hoping that I could just switch the Rinehart slip on muffler to a different size but after a ton of research that's not gonna happen. Rinehart makes a 3.5" pipe but its for their touring dual system and the inlet is MUCH smaller than the 2 into 1.
Old Jun 27, 2013 | 08:31 AM
hd4evr2008's Avatar
hd4evr2008
Since we have all the new fuels, I was told that you can't tell much at all from looking at plugs anymore. The new gas burns "clean" and the plugs will look white/lean when they aren't.
Old Jun 27, 2013 | 08:44 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I'm no pro, so let me get that out of the way.
Most people here say, slip ons need no extra engine work. Adding full pipes/AC does. Personally I would, even if you had it does before when you added the 2-1 pipes.
Old Jun 27, 2013 | 09:26 AM
jgcable's Avatar
jgcable
I don't know if the bike was ever re-mapped. I bought it from the dealership a year ago and it had the Rinehart 2 into 1 on it. It runs amazing with no issues at all.
There are actually 2 things I don't like about the pipe though.
#1. I can't use it with my saddlebags
#2. I really was never a fan of how it looks. The tip was black and it turned a dark purple and looks aweful. I also don't like the megaphone style of the muffler.
I do get compliments all the time on how it sounds though and it really performs.
I have always been a fan of the Vance & Hines Staggered Short Shots and they are very affordable but its a tough decision removing a super high performance $800.00 exhaust and replacing it with a $350.00 exhaust that most people say I will be disappointed with performance wise. My bike is totally stock with the exception of the Stage 1 air cleaner and the exhaust. Also.. I am not a speed freak. I go for more looks and sound.
Old Jun 27, 2013 | 05:35 PM
loopie's Avatar
loopie
over here in Australia our fuel sends the plugs black over a long period, hence why its only a quick guide, even our pipes are black inside.. but when you use avgas 100% octane no issues then , a nice grey /tan colour..
THE only real test is using a lamba probe too check emmissions coming from the exhaust while dyno tunning
Old Jun 27, 2013 | 06:15 PM
Gliden's Avatar
Gliden
A cheap read would be drop new plugs in for 10 bucks and put 500 miles on the bike.
Pull the plugs and look at them. ( read them)
Look up on google images for comparisons of a normal plug, rich running bike or lean running bike.
mdriggs
Oct 8, 2017 03:29 PM
Essentialbill
Jun 8, 2013 12:37 AM
Divinitus
May 1, 2012 09:41 AM
fattdog
Oct 2, 2008 11:53 PM
jhoffa
Dec 3, 2007 12:45 PM
