Handlebar Troubles HELP!
Old Jun 28, 2013 | 06:01 PM
DeaD SpacE's Avatar
DeaD SpacE
Default Handlebar Troubles HELP!
Ok I bought some chrome Burly drag bars.Installed them ten minutes ago
and I was test fitting things and my Avon grips would not go on the bars
without a lot of force.So I also tried a set of ISO grips I have and same
thing.It seems like the chrome plating is to thick.
Is there a trick,do I need to sand off the chrome on the throttle side?
Old Jun 29, 2013 | 03:04 AM
Tat2u's Avatar
Tat2u
even the throttle side? that's not good. there should be heaps of clearance its going to be hard to sand off what you need to. I would be returning them and wouldn't be happy about it
Old Jun 29, 2013 | 10:37 AM
dirtdobber's Avatar
dirtdobber
I ran into this on a set of powder coated bars.
I just sanded them down, added some light grease.
Chrome is not very thick I would check with the vender, they might have had a bad batch of bars.
Old Jun 29, 2013 | 10:54 AM
DeaD SpacE's Avatar
DeaD SpacE
I emailed the vendor probably be monday before I hear anything.
I'm also very impatient and have already started sanding,I'm getting their LOL.
Old Jun 29, 2013 | 11:03 AM
dirtdobber's Avatar
dirtdobber
If you have a belt sander that will speed things up really easy, then finish by hand.
Old Jun 29, 2013 | 11:07 AM
DeaD SpacE's Avatar
DeaD SpacE
I wish I had a belt sander,this is going to be a major hand job haha.
Old Jun 29, 2013 | 11:10 AM
dirtdobber's Avatar
dirtdobber
Cut your sand paper rather long. Use it by rotating it back and forth. This will keep your hands from hurting plus it will cover a larger area at the same time.
Old Jun 29, 2013 | 11:14 AM
DeaD SpacE's Avatar
DeaD SpacE
Yep exactly how I have been doing it.I need some heavier grit only have 220
going to store see if I can get some 180.Thanks for the help.
Night Stalker
Mar 27, 2011 08:47 PM
ed gien
Feb 3, 2011 11:48 PM
scott_db
Apr 29, 2009 11:10 PM
STEG
Jul 20, 2007 08:44 AM
tracymason
Feb 11, 2006 09:00 PM
