Wanted: your wisdom
Old Jul 15, 2013 | 02:12 AM
3illy's Avatar
3illy
Default Wanted: your wisdom
Hi, I just ordered up the HD LED turn signals with smoked lenses, front and back, for my 2013 FXDF. I was thinking about doing the install myself. So I've been reading my 2013 Dyna Service manual and things seem pretty straight forward.
The service manual has me moving or pulling the gas tank back. When I disconnect the quick connect gas line, is there some kinda valve that will keep the fuel in the tank from leaking out? Or do I need to figure a way to drain the tank?
Be real happy to hear from folks who have replaced their front turn signals on their 2013 or late model Dyna's. Any hints, tricks, tips or gotchas?
Thank You
Old Jul 15, 2013 | 02:30 AM
DonN's Avatar
DonN
There is a valve to prevent all from coming out, but the hose is under pressure so some will lead out. Have a bottle or rag ready.
I think you can pull the fuel pump fuse and run the motor to it cuts off as well.
DonN's Avatar
DonN
double post
Old Jul 15, 2013 | 03:03 AM
3illy's Avatar
3illy
Gotcha, just looked up the procedure in the manual to dissipate fuel pump pressure! thanks!
Old Jul 15, 2013 | 05:38 AM
blueangel73's Avatar
blueangel73
I could be wrong, but you should be able to access the wire harness under the neck without having to move the tank at all, if anything you might have to slide the tank back a little. But I don't see why you would need to pull it off, to me its a justification for the shop to charge more in labor nothing more.
Old Jul 15, 2013 | 07:59 AM
HD Pilot's Avatar
HD Pilot
When you move your tank backwards, have some clean rags/towels ready to put under the tank to protect the cylinder heads and fuel crossover line.
the_red_engine
Mar 13, 2018 04:50 PM
Big Lebowski
Jul 18, 2013 12:54 PM
boosting1bar
Apr 7, 2013 05:10 AM
ugatha
Jul 22, 2012 06:36 PM
coconut
Exhaust System Topics
Sep 20, 2007 02:09 AM
