What tool do you use?
Old Aug 10, 2013 | 11:05 PM
davidnewtonparr's Avatar
davidnewtonparr
Default What tool do you use?
I started my cam project today, and I got most of it done; new cam plate, oil pump, hydraulic tensioners, TW555 cams, lifters, new cam plate cover... Tomorrow I have to reinstall the lifter blocks, pushrods and pushrod tubes.
I ran into some trouble removing the lifter blocks. The only thing I could use to remove the four bolts up close to the jugs was a regular 3/16 allen wrench and a lot of patience. Tomorrow I'm going to put them back in... I can use the same technique, however, the only torque value I can be sure of getting back there is "PFT"... Should be alright? What technique or tool do others use to get this part torqued when you are not removing the heads and jugs?
I can't find a shorter allen wrench and a socket sure won't fit... I'm planning on cutting down my allen wrench so that at least it will fit better.
Thank You
Old Aug 10, 2013 | 11:11 PM
soft 02's Avatar
soft 02
Just tighten them evenly in a crossing pattern till they are tight enough. You could torque the easy ones and check with your hand allen and approximate how tight the rear should be. They are not prone to leaking and are not structural so you should be fine.
Old Aug 10, 2013 | 11:19 PM
davidnewtonparr
Originally Posted by soft 02
Just tighten them evenly in a crossing pattern till they are tight enough. You could torque the easy ones and check with your hand allen and approximate how tight the rear should be. They are not prone to leaking and are not strictual so you should be fine.
Thank You
Old Aug 11, 2013 | 04:37 AM
rasmukri's Avatar
rasmukri
+1
Pretty much waht i did. you get a feel for where it should be after a while
Old Aug 11, 2013 | 09:06 AM
thedonthere's Avatar
thedonthere
get a set of ball end allen wrenches...
Old Aug 11, 2013 | 09:11 AM
Crazy's Avatar
Crazy
Exactly how I did it as well.
Old Aug 11, 2013 | 09:12 AM
heritageblue2013's Avatar
heritageblue2013
I use my man tool. It works on any woman. And for the really tough jobs the man tool encounters, I use Amsoil.
Bushrider
Apr 7, 2012 04:43 AM
harley_jeff
Exhaust System Topics
Dec 22, 2011 09:35 PM
Rolldog
Feb 20, 2008 09:55 PM
GeneP
Jul 13, 2005 05:55 PM
