True Track- does this look right?
Old Aug 27, 2013 | 11:22 AM
johnjay's Avatar
johnjay
My 2006 Street Bob has it on along with an oil cooler.. Fit perfectly after playing with it. I think it made a big difference on the curves and the general tightness of the bike, that said I also put good shocks and rebuilt the forks with Race Tech kit. Added a fork brace and changed the brakes to Performance Machine's 6 piston/4 piston brake calipers with Lyndall racing discs. So with all this it's not one thing but the entire upgrade of components. But in the twisties I feel a big difference in that you can pull tighter corners at a faster speed.
Old Aug 27, 2013 | 05:07 PM
Ratbob's Avatar
Ratbob
You really don't want those two edges in contact. Remove one bolt from each Heim joint (front and rear), loosen the motor mount bolts, and run the engine alignment procedure.
Old Aug 27, 2013 | 05:23 PM
upflying's Avatar
upflying
Originally Posted by ynots
its a stabilizer that helps keep your motor from dancing around it the rubber mounts
Thanks, I pulled up the True Track website. Makes a lot of promises which makes me wonder why HD doesn't install it OEM if it's so good.
Old Aug 27, 2013 | 06:04 PM
fxdlx's Avatar
fxdlx
Probably 'cuz they're going the cheap route...
Scratt
Mar 4, 2012 07:22 PM
blugsr
Nov 7, 2009 06:51 AM
