Another Dyna Hard Bag Conversion
Old Aug 28, 2013 | 03:27 PM
Ndfastln's Avatar
Ndfastln
Default Another Dyna Hard Bag Conversion
I really like the looks of the hard bags, on a Dyna or not. So I thought long and hard about how to modify the bags to fit, and the brackets to install them. After pondering it for a month or so I see a post where someone had done a set of bags and installed a fairing, both with quick detach hardware and easily removable. Perfect, exactly what I wanted to do, so here goes.
I found a set of bags on Ebay used for $160.00 so ordered them, a set of aftermarket hardware and found a set of HD latch covers. Since the bags are made of ABS I bought some 4" ABS drain pipe, cut the bags and glued them in, moved the tab that holds the lid in the front to the middle, and fabbed some brackets.
This winter I will extend the rear fender and fab some filler panels to the saddlebag brackets, so they can be removed also. The bags have just been painted and are drying atm. I will post pics of them soon. Now to relocate the license plate, find some lights I like, and a fairing, 21" wheel and maybe a raked triple. (Where does it end!!! lol). I plan on some custom paint this winter if I have time and can decide on a scheme I like.
Old Aug 28, 2013 | 03:30 PM
Ndfastln's Avatar
Ndfastln
BTW the passenger pillion, won't be on there without the sissy bar and backrest. I plan to keep it all off unless the OL decides she wants to ride
Old Aug 28, 2013 | 03:37 PM
Robtarra39's Avatar
Robtarra39
Just curious, but did you use ABS glue or a plastic type glue
Old Aug 28, 2013 | 04:26 PM
Converted_HD's Avatar
Converted_HD
Still on the fence for hard or soft bags.....
Old Aug 28, 2013 | 04:55 PM
Ndfastln's Avatar
Ndfastln
I used 2 different epoxies for ABS
Old Aug 28, 2013 | 05:24 PM
rawb101's Avatar
rawb101
NDfastin, im also looking for bags. i have a 2013 SB debating on soft or hard. I think i just made my decision... LOOKS FREAKN AWESOME MAN!!
Old Aug 28, 2013 | 05:25 PM
06BlackWG's Avatar
06BlackWG
I'm headed in that direction. Have the bags, lids, brackets. Like the ABS pipe idea. Waiting for the weather to cool down before starting. Not sure about my rear fender. May need to find something different. Love to see how you fill in the gaps. What do you plan on using.
Old Aug 28, 2013 | 06:59 PM
sharkey's Avatar
sharkey
Some real fine fabbin' there; like them a lot...time and skill to make what you want work
Old Aug 28, 2013 | 07:46 PM
sonnydaze's Avatar
sonnydaze
im trying to decide on hard or soft bags
Old Aug 28, 2013 | 10:18 PM
Ndfastln's Avatar
Ndfastln
I'll just bend up some sheetmetal until it looks right, lol. I'm still tossing around ideas but I may use some exhaust pipe, mandrel bent, and cut roughly in half, for a curve then maybe tack some sheetmetal for the flat areas. It'll be a couple months before I get around to that. Several trips planned, and busy season coming up.
