Question on left side crank locking tool
Old Aug 30, 2013 | 02:40 PM
clovisrider's Avatar
clovisrider
Default Question on left side crank locking tool
I have a 2000 dyna twin cam motor out of the bike and need to lock the crank shaft to loosen the bolts on the drive gears. It has been upgraded to S & S gear drive cams.
Is this the only tool to do the job, and is it the correct one for the 10 spline crank shaft?
Thank-you
Jims Engine Rotator 976 Harley Davidson
Old Aug 30, 2013 | 03:28 PM
Spanners39's Avatar
Spanners39
If the motor is out of the bike you can leave the plugs in and tap the wrench with a hammer. OR feed a length of 8mm rope down the plug hole (leave a tail so you can get it out) this will lock the motor with no damage. You can do the same to tighten it.
Old Aug 30, 2013 | 04:17 PM
clovisrider
Spanners39,
I'll give that a try. I have the spline ratcheting wrench, but it has a really narrow spline contact patch and was afraid it would damage the splines.
This tool was the only other thing I've found.
Thank-you
Old Aug 30, 2013 | 05:34 PM
Spanners39's Avatar
Spanners39
Anyone who ever worked on Ironheads and Shovels knows that trick, you want about 3 feet of soft rope. Try your local rock-climbing shop for some sheathed multi-core stuff.
Mike Lawless
Engine Mechanical Topics
Oct 31, 2016 04:51 AM
Wampa Stomper
General Topics/Tech Tips
May 17, 2015 05:47 PM
brberk
Exhaust System Topics
Nov 18, 2012 04:01 PM
harley_jeff
Dec 22, 2011 09:35 PM
Rolldog
Feb 20, 2008 09:55 PM
