Streetbob Handlebar/tank question
Old Aug 30, 2013 | 10:09 PM
gadgetguy1288's Avatar
gadgetguy1288
Default Streetbob Handlebar/tank question
Call me crazy, but I love the bars and the "unclutered" look of the speedo/bars on the Blackline, and I want to replicate that look on a 14 Streetbob. Anyone know if the stock Blackline triple tree would fit the streetbob, and if the panel on the Blackline tank would fit the streetbob?
Old Aug 30, 2013 | 11:10 PM
203Cree's Avatar
203Cree
Tank is bigger on the FXS, and the trees are wide glides, so IF you tried to swap stuff, you'd need upper and lower trees and a wide glide hub for your front wheel.
Old Aug 31, 2013 | 09:23 AM
SquidHead's Avatar
SquidHead
There are countless bars out there that will fit your SB without changing the front end. You just have to start searching for what you like.
Then find a bar clamp or clamp/riser combo that has a speedo mount, and you're good.
Joker Machine makes some cool clamps that might work for you.
Old Aug 31, 2013 | 12:20 PM
brandon95354's Avatar
brandon95354
your dyna forks wont work with black line trees, 49mm fork in a 41mm tree. you can get a 06-09 super glide tank and relocate your speedo to the bars, should be a simple swap.
Old Aug 31, 2013 | 12:37 PM
203Cree's Avatar
203Cree
Ohhh, good call. Forgot all about that.
Old Aug 31, 2013 | 12:40 PM
jmeiers's Avatar
jmeiers
I'm calling you crazy!
Old Aug 31, 2013 | 03:48 PM
gadgetguy1288
The Harley drag bars I could live with. But I wouldn't be able to just relocate the speedo and use the Blackline tank plastic tank panel? I dont want the whole tank, just that center black panel.
Old Aug 31, 2013 | 05:01 PM
brandon95354
if your really wanting to do this, look up the only dyna roland sands ever built on his website. a guy in so cal can make you a custom dash for a fxdb, and you will find the info on he relocated the speedo, or get a fork mount speedo from joker as already mentioned.
you need to take off your dyna dash and get some poster type thick paper, then cut out a template of what dash design you want and mark the spots for the bolt holes, then you will send the dash builder the template and in a few weeks you will have a dash. this is something i am currently in the process of doing i should send out my template soon. your template does not have to be 100% perfect and symmetrical, the builder will just use it as a base, but your bolt measurements need to be exact.
sounds like lots of work, but it is actually very simple
Old Aug 31, 2013 | 05:30 PM
gadgetguy1288
Damn. I was really hoping the dash would be just a simple switch. Looks like I'm the hunt for a leftover Blackline instead then. Thanks guys!
straydog13
Jul 24, 2011 10:16 AM
HogGlider
Nov 27, 2007 11:27 PM
New Dyna Guy
May 12, 2007 01:51 AM
buckweet
Apr 13, 2007 03:33 PM
98fxd
Jun 10, 2005 06:01 PM
